Howdoyoudo?
What am I doing wrong?
Tue Jun 30, 2020 5:14 pm
My Rpi states I have
i@raspberrypi:~ $ ls -ltr /dev/video*
crw-rw----+ 1 root video 81, 0 Jun 29 21:01 /dev/video10
crw-rw----+ 1 root video 81, 1 Jun 29 21:01 /dev/video11
crw-rw----+ 1 root video 81, 2 Jun 29 21:01 /dev/video12
crw-rw----+ 1 root video 81, 5 Jun 30 12:48 /dev/video2
crw-rw----+ 1 root video 81, 6 Jun 30 12:48 /dev/video3
crw-rw----+ 1 root video 81, 3 Jun 30 12:51 /dev/video0
crw-rw----+ 1 root video 81, 4 Jun 30 12:51 /dev/video1
crw-rw----+ 1 root video 81, 7 Jun 30 12:57 /dev/video4
crw-rw----+ 1 root video 81, 8 Jun 30 12:57 /dev/video5
9 cameras hooked up I only have 3 usb cameras hooked up and not one of them displays an image.
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.118-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1311 SMP Mon Apr 27 14:21:24 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu s36864 r8192 d20480 u65536
[ 0.000000] pcpu-alloc: s36864 r8192 d20480 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1366 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939064K/970752K available (8192K kernel code, 656K rwdata, 2232K rodata, 1024K init, 831K bss, 23496K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (9184 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 657 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 832 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27093 entries in 80 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000019] Switching to timer-based delay loop, resolution 52ns
[ 0.000267] Console: colour dummy device 80x30
[ 0.000287] console [tty1] enabled
[ 0.000329] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000343] pid_max: default: 32768 minimum: 301
[ 0.000692] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000708] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001641] CPU: Testing write buffer coherency: ok
[ 0.002101] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002759] Setting up static identity map for 0x100000 - 0x10003c
[ 0.002908] rcu: Hierarchical SRCU implementation.
[ 0.003715] smp: Bringing up secondary CPUs ...
[ 0.004608] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005583] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006497] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006609] smp: Brought up 1 node, 4 CPUs
[ 0.006621] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006627] CPU: All CPU(s) started in HYP mode.
[ 0.006632] CPU: Virtualization extensions available.
[ 0.007610] devtmpfs: initialized
[ 0.021133] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.021371] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.021391] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.021980] pinctrl core: initialized pinctrl subsystem
[ 0.022837] NET: Registered protocol family 16
[ 0.026109] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.032103] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.032111] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.032309] Serial: AMBA PL011 UART driver
[ 0.034629] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.050039] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-04-15 11:43, variant start
[ 0.060051] raspberrypi-firmware soc:firmware: Firmware hash is 82f9bb929ce2186eb1824178c1ae82902ad6275c
[ 0.103343] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.104964] SCSI subsystem initialized
[ 0.105185] usbcore: registered new interface driver usbfs
[ 0.105239] usbcore: registered new interface driver hub
[ 0.105333] usbcore: registered new device driver usb
[ 0.107157] clocksource: Switched to clocksource arch_sys_counter
[ 0.197761] VFS: Disk quotas dquot_6.6.0
[ 0.197842] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.198023] FS-Cache: Loaded
[ 0.198230] CacheFiles: Loaded
[ 0.208283] NET: Registered protocol family 2
[ 0.209121] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.209157] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.209268] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.209453] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.209590] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209641] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209879] NET: Registered protocol family 1
[ 0.210468] RPC: Registered named UNIX socket transport module.
[ 0.210475] RPC: Registered udp transport module.
[ 0.210480] RPC: Registered tcp transport module.
[ 0.210486] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.212398] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.215467] Initialise system trusted keyrings
[ 0.215668] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.225599] FS-Cache: Netfs 'nfs' registered for caching
[ 0.226171] NFS: Registering the id_resolver key type
[ 0.226201] Key type id_resolver registered
[ 0.226208] Key type id_legacy registered
[ 0.226224] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.231758] Key type asymmetric registered
[ 0.231770] Asymmetric key parser 'x509' registered
[ 0.231828] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.231995] io scheduler noop registered
[ 0.232003] io scheduler deadline registered (default)
[ 0.232201] io scheduler cfq registered
[ 0.232209] io scheduler mq-deadline registered (default)
[ 0.232216] io scheduler kyber registered
[ 0.235444] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.265702] Console: switching to colour frame buffer device 170x48
[ 0.282279] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1366x768
[ 0.284426] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.284732] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.285237] vc-sm: Videocore shared memory driver
[ 0.285554] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.296409] brd: module loaded
[ 0.306712] loop: module loaded
[ 0.307379] Loading iSCSI transport class v2.0-870.
[ 0.308093] libphy: Fixed MDIO Bus: probed
[ 0.308195] usbcore: registered new interface driver lan78xx
[ 0.308251] usbcore: registered new interface driver smsc95xx
[ 0.308268] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.336121] dwc_otg 3f980000.usb: base=(ptrval)
[ 0.536375] Core Release: 2.80a
[ 0.536385] Setting default values for core params
[ 0.536416] Finished setting default values for core params
[ 0.736727] Using Buffer DMA mode
[ 0.736735] Periodic Transfer Interrupt Enhancement - disabled
[ 0.736741] Multiprocessor Interrupt Enhancement - disabled
[ 0.736748] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.736765] Dedicated Tx FIFOs mode
[ 0.737269] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
[ 0.737296] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.737304] dwc_otg: Microframe scheduler enabled
[ 0.737355] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.737364] WARN::hcd_init_fiq:458: FIQ ASM at 8068fda0 length 36
[ 0.737375] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 0.737392] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.737457] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.737497] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 0.737546] Init: Port Power? op_state=1
[ 0.737553] Init: Power Port (0)
[ 0.737812] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.737824] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.737833] usb usb1: Product: DWC OTG Controller
[ 0.737842] usb usb1: Manufacturer: Linux 4.19.118-v7+ dwc_otg_hcd
[ 0.737850] usb usb1: SerialNumber: 3f980000.usb
[ 0.738470] hub 1-0:1.0: USB hub found
[ 0.738516] hub 1-0:1.0: 1 port detected
[ 0.739107] dwc_otg: FIQ enabled
[ 0.739112] dwc_otg: NAK holdoff enabled
[ 0.739118] dwc_otg: FIQ split-transaction FSM enabled
[ 0.739128] Module dwc_common_port init
[ 0.739388] usbcore: registered new interface driver usb-storage
[ 0.739566] mousedev: PS/2 mouse device common for all mice
[ 0.740402] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.740635] bcm2835-cpufreq: min=600000 max=1200000
[ 0.741085] sdhci: Secure Digital Host Controller Interface driver
[ 0.741091] sdhci: Copyright(c) Pierre Ossman
[ 0.741473] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 0.741876] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.742001] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.743690] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.743882] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.744036] usbcore: registered new interface driver usbhid
[ 0.744041] usbhid: USB HID core driver
[ 0.745000] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.746490] [vc_sm_connected_init]: start
[ 0.755658] [vc_sm_connected_init]: end - returning 0
[ 0.756780] Initializing XFRM netlink socket
[ 0.756806] NET: Registered protocol family 17
[ 0.756931] Key type dns_resolver registered
[ 0.757727] Registering SWP/SWPB emulation handler
[ 0.758381] registered taskstats version 1
[ 0.758398] Loading compiled-in X.509 certificates
[ 0.765117] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.765205] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.767044] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.767055] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 0.793439] sdhost: log_buf @ (ptrval) (fad07000)
[ 0.832969] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.834546] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.836126] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.838954] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.841343] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.842642] of_cfs_init
[ 0.842737] of_cfs_init: OK
[ 0.843411] Waiting for root device /dev/mmcblk0p7...
[ 0.900725] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.903382] mmc0: new high speed SDHC card at address 5048
[ 0.904670] mmcblk0: mmc0:5048 SD32G 28.9 GiB
[ 0.908619] mmcblk0: p1 p2 < p5 p6 p7 >
[ 0.912136] random: fast init done
[ 0.945179] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.945234] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.954244] devtmpfs: mounted
[ 0.962305] Freeing unused kernel memory: 1024K
[ 0.965503] mmc1: new high speed SDIO card at address 0001
[ 0.967305] Indeed it is in host mode hprt0 = 00021501
[ 1.027708] Run /sbin/init as init process
[ 1.177215] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.177362] Indeed it is in host mode hprt0 = 00001101
[ 1.417579] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 1.417605] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.418302] hub 1-1:1.0: USB hub found
[ 1.418399] hub 1-1:1.0: 5 ports detected
[ 1.638162] systemd[1]: System time before build time, advancing clock.
[ 1.737211] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.773813] NET: Registered protocol family 10
[ 1.775121] Segment Routing with IPv6
[ 1.813919] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.814810] systemd[1]: Detected architecture arm.
[ 1.822818] systemd[1]: Set hostname to <raspberrypi>.
[ 1.867833] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 1.867852] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.871014] smsc95xx v1.0.6
[ 1.961784] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:cd:99:84
[ 2.057249] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 2.214243] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.07
[ 2.214259] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.214268] usb 1-1.2: Product: USB Receiver
[ 2.214277] usb 1-1.2: Manufacturer: Logitech
[ 2.357226] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[ 2.509125] usb 1-1.4: New USB device found, idVendor=0d3d, idProduct=0001, bcdDevice= 0.01
[ 2.509141] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.509150] usb 1-1.4: Product: USBPS2
[ 2.527312] input: USBPS2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0D3D:0001.0004/input/input0
[ 2.598013] hid-generic 0003:0D3D:0001.0004: input,hidraw0: USB HID v1.00 Keyboard [USBPS2] on usb-3f980000.usb-1.4/input0
[ 2.615103] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.618487] input: USBPS2 Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0D3D:0001.0005/input/input1
[ 2.618964] input: USBPS2 Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0D3D:0001.0005/input/input2
[ 2.626966] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.627865] systemd[1]: Listening on Journal Socket.
[ 2.628449] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.628730] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.656559] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.665696] systemd[1]: Starting Set the console keyboard layout...
[ 2.668035] systemd[1]: Created slice system-getty.slice.
[ 2.669946] systemd[1]: Created slice User and Session Slice.
[ 2.671294] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.687530] input: USBPS2 System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0D3D:0001.0005/input/input3
[ 2.697450] hid-generic 0003:0D3D:0001.0005: input,hidraw1: USB HID v1.00 Mouse [USBPS2] on usb-3f980000.usb-1.4/input1
[ 2.807260] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
[ 2.845347] i2c /dev entries driver
[ 2.939391] usb 1-1.5: New USB device found, idVendor=0451, idProduct=2046, bcdDevice= 1.25
[ 2.939410] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.940406] hub 1-1.5:1.0: USB hub found
[ 2.941020] hub 1-1.5:1.0: 4 ports detected
[ 3.257326] usb 1-1.5.1: new full-speed USB device number 7 using dwc_otg
[ 3.267525] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 3.389131] usb 1-1.5.1: config 1 interface 1 altsetting 3 endpoint 0x85 has invalid maxpacket 1024, setting to 1023
[ 3.389150] usb 1-1.5.1: config 1 interface 3 has no altsetting 1
[ 3.390345] usb 1-1.5.1: New USB device found, idVendor=1b3f, idProduct=2202, bcdDevice= 1.00
[ 3.390358] usb 1-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.390367] usb 1-1.5.1: Product: GENERAL - UVC
[ 3.390376] usb 1-1.5.1: Manufacturer: GENERAL
[ 3.425111] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 4.230222] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.233004] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.233018] [vc_sm_connected_init]: start
[ 4.239399] [vc_sm_connected_init]: installed successfully
[ 4.260447] media: Linux media interface: v0.10
[ 4.310603] videodev: Linux video capture interface: v2.00
[ 4.351505] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.365652] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.371129] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.385909] bcm2835_audio soc:audio: card created with 4 channels
[ 4.389769] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.394247] bcm2835_audio soc:audio: card created with 4 channels
[ 4.409322] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.451146] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.451191] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.458551] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.458592] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.468297] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.468335] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.755511] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.2/input2
[ 4.820566] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.880227] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.903811] input: Logitech Unifying Device. Wireless PID:400a Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:400A.0006/input/input4
[ 4.904333] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:400a] on usb-3f980000.usb-1.2:1
[ 4.958774] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 4.970989] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 4.971336] usbcore: registered new interface driver brcmfmac
[ 5.198696] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 5.198814] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 5.199609] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[ 5.806794] uvcvideo: Found UVC 1.00 device GENERAL - UVC (1b3f:2202)
[ 5.815728] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[ 5.816716] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 5 was not initialized!
[ 5.816732] uvcvideo 1-1.5.1:1.0: Entity type for entity Selector 4 was not initialized!
[ 5.816744] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
[ 5.817353] input: GENERAL - UVC : GENERAL - UVC as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input8
[ 5.826146] usbcore: registered new interface driver uvcvideo
[ 5.826157] USB Video Class driver (1.1.1)
[ 5.858240] usbcore: registered new interface driver snd-usb-audio
[ 5.862323] random: crng init done
[ 5.862338] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.114890] input: Logitech M325 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:400A.0006/input/input9
[ 6.115626] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech M325] on usb-3f980000.usb-1.2:1
[ 7.641211] uart-pl011 3f201000.serial: no DMA platform data
[ 7.773273] 8021q: 802.1Q VLAN Support v1.8
[ 7.991812] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.326343] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.326384] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.839602] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.840212] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.769415] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 11.189235] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 11.794085] Bluetooth: Core ver 2.22
[ 11.794193] NET: Registered protocol family 31
[ 11.794196] Bluetooth: HCI device and connection manager initialized
[ 11.796379] Bluetooth: HCI socket layer initialized
[ 11.796390] Bluetooth: L2CAP socket layer initialized
[ 11.796424] Bluetooth: SCO socket layer initialized
[ 11.814757] Bluetooth: HCI UART driver ver 2.3
[ 11.814768] Bluetooth: HCI UART protocol H4 registered
[ 11.814880] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 11.815037] Bluetooth: HCI UART protocol Broadcom registered
[ 12.108312] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.108320] Bluetooth: BNEP filters: protocol multicast
[ 12.108336] Bluetooth: BNEP socket layer initialized
[ 12.174427] Bluetooth: RFCOMM TTY layer initialized
[ 12.174467] Bluetooth: RFCOMM socket layer initialized
[ 12.174510] Bluetooth: RFCOMM ver 1.11
[ 13.773083] fuse init (API version 7.27)
[43668.072212] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.072958] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.073576] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.074453] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.075078] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.078462] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[43668.079080] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[56780.890593] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56781.022656] restoring control 00000000-0000-0000-0000-000000000101/0/2
[56781.022668] restoring control 00000000-0000-0000-0000-000000000101/1/3
[56781.022676] restoring control 00000000-0000-0000-0000-000000000101/2/6
[56781.022683] restoring control 00000000-0000-0000-0000-000000000101/3/7
[56781.022691] restoring control 00000000-0000-0000-0000-000000000101/4/8
[56781.022699] restoring control 00000000-0000-0000-0000-000000000101/5/9
[56781.022706] restoring control 00000000-0000-0000-0000-000000000101/8/1
[56786.270627] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56786.402658] restoring control 00000000-0000-0000-0000-000000000101/0/2
[56786.402670] restoring control 00000000-0000-0000-0000-000000000101/1/3
[56786.402678] restoring control 00000000-0000-0000-0000-000000000101/2/6
[56786.402685] restoring control 00000000-0000-0000-0000-000000000101/3/7
[56786.402693] restoring control 00000000-0000-0000-0000-000000000101/4/8
[56786.402700] restoring control 00000000-0000-0000-0000-000000000101/5/9
[56786.402707] restoring control 00000000-0000-0000-0000-000000000101/8/1
[56800.090700] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56800.222656] restoring control 00000000-0000-0000-0000-000000000101/0/2
[56800.222669] restoring control 00000000-0000-0000-0000-000000000101/1/3
[56800.222676] restoring control 00000000-0000-0000-0000-000000000101/2/6
[56800.222684] restoring control 00000000-0000-0000-0000-000000000101/3/7
[56800.222691] restoring control 00000000-0000-0000-0000-000000000101/4/8
[56800.222699] restoring control 00000000-0000-0000-0000-000000000101/5/9
[56800.222707] restoring control 00000000-0000-0000-0000-000000000101/8/1
[56802.650715] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56802.782775] restoring control 00000000-0000-0000-0000-000000000101/0/2
[56802.782788] restoring control 00000000-0000-0000-0000-000000000101/1/3
[56802.782796] restoring control 00000000-0000-0000-0000-000000000101/2/6
[56802.782803] restoring control 00000000-0000-0000-0000-000000000101/3/7
[56802.782811] restoring control 00000000-0000-0000-0000-000000000101/4/8
[56802.782818] restoring control 00000000-0000-0000-0000-000000000101/5/9
[56802.782825] restoring control 00000000-0000-0000-0000-000000000101/8/1
[56807.520737] usb 1-1.5.2: new full-speed USB device number 8 using dwc_otg
[56817.760795] usb 1-1.5.2: new full-speed USB device number 9 using dwc_otg
[56817.895063] usb 1-1.5.2: config 1 interface 3 has no altsetting 1
[56817.897518] usb 1-1.5.2: New USB device found, idVendor=1b3f, idProduct=2202, bcdDevice= 1.00
[56817.897531] usb 1-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56817.897540] usb 1-1.5.2: Product: GENERAL - UVC
[56817.897549] usb 1-1.5.2: Manufacturer: GENERAL
[56817.900404] uvcvideo: Found UVC 1.00 device GENERAL - UVC (1b3f:2202)
[56817.911135] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[56817.912093] uvcvideo 1-1.5.2:1.0: Entity type for entity Processing 5 was not initialized!
[56817.912110] uvcvideo 1-1.5.2:1.0: Entity type for entity Selector 4 was not initialized!
[56817.912122] uvcvideo 1-1.5.2:1.0: Entity type for entity Camera 1 was not initialized!
[56817.912542] input: GENERAL - UVC : GENERAL - UVC as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.0/input/input10
[56979.082021] usb 1-1.5-port1: Cannot enable. Maybe the USB cable is bad?
[56979.181673] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56979.721672] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56980.161669] usb 1-1.5.1: device not accepting address 7, error -22
[56980.261677] usb 1-1.5.1: reset full-speed USB device number 7 using dwc_otg
[56980.701673] usb 1-1.5.1: device not accepting address 7, error -22
[56980.702398] usb 1-1.5.1: USB disconnect, device number 7
[56980.891709] usb 1-1.5.1: new full-speed USB device number 10 using dwc_otg
[56981.023428] usb 1-1.5.1: config 1 interface 1 altsetting 3 endpoint 0x85 has invalid maxpacket 1024, setting to 1023
[56981.023450] usb 1-1.5.1: config 1 interface 3 has no altsetting 1
[56981.024642] usb 1-1.5.1: New USB device found, idVendor=1b3f, idProduct=2202, bcdDevice= 1.00
[56981.024655] usb 1-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56981.024664] usb 1-1.5.1: Product: GENERAL - UVC
[56981.024673] usb 1-1.5.1: Manufacturer: GENERAL
[56981.026909] uvcvideo: Found UVC 1.00 device GENERAL - UVC (1b3f:2202)
[56981.030016] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[56981.030933] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 5 was not initialized!
[56981.030947] uvcvideo 1-1.5.1:1.0: Entity type for entity Selector 4 was not initialized!
[56981.030959] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
[56981.031380] input: GENERAL - UVC : GENERAL - UVC as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input11
[56981.141716] usb 1-1.5.2: reset full-speed USB device number 9 using dwc_otg
[56989.322150] usb 1-1.5-port1: Cannot enable. Maybe the USB cable is bad?
[56989.421738] usb 1-1.5.1: reset full-speed USB device number 10 using dwc_otg
[56989.961736] usb 1-1.5.1: reset full-speed USB device number 10 using dwc_otg
[56990.401737] usb 1-1.5.1: device not accepting address 10, error -22
[56990.501746] usb 1-1.5.1: reset full-speed USB device number 10 using dwc_otg
[56990.941736] usb 1-1.5.1: device not accepting address 10, error -22
[56990.942527] usb 1-1.5.1: USB disconnect, device number 10
[56991.151712] usb 1-1.5.1: new full-speed USB device number 11 using dwc_otg
[56991.284640] usb 1-1.5.1: config 1 interface 1 altsetting 3 endpoint 0x85 has invalid maxpacket 1024, setting to 1023
[56991.284651] usb 1-1.5.1: config 1 interface 3 has no altsetting 1
[56991.285745] usb 1-1.5.1: New USB device found, idVendor=1b3f, idProduct=2202, bcdDevice= 1.00
[56991.285752] usb 1-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[56991.285756] usb 1-1.5.1: Product: GENERAL - UVC
[56991.285761] usb 1-1.5.1: Manufacturer: GENERAL
[56991.287506] uvcvideo: Found UVC 1.00 device GENERAL - UVC (1b3f:2202)
[56991.290618] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[56991.291305] uvcvideo 1-1.5.1:1.0: Entity type for entity Processing 5 was not initialized!
[56991.291314] uvcvideo 1-1.5.1:1.0: Entity type for entity Selector 4 was not initialized!
[56991.291320] uvcvideo 1-1.5.1:1.0: Entity type for entity Camera 1 was not initialized!
[56991.291537] input: GENERAL - UVC : GENERAL - UVC as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.1/1-1.5.1:1.0/input/input12
[56996.951776] usb 1-1.5.1: reset full-speed USB device number 11 using dwc_otg
[57002.331811] usb 1-1.5.1: reset full-speed USB device number 11 using dwc_otg
[57004.509126] logitech-hidpp-device 0003:046D:400A.0006: HID++ 2.0 device connected.
[57209.952941] usb 1-1.5.1: reset full-speed USB device number 11 using dwc_otg
[57213.532928] usb 1-1.5.1: reset full-speed USB device number 11 using dwc_otg
[57230.433039] usb 1-1.5.1: reset full-speed USB device number 11 using dwc_otg
[57332.313559] usb 1-1.5.3: new full-speed USB device number 12 using dwc_otg
[57332.455317] usb 1-1.5.3: config 1 interface 3 has no altsetting 1
[57332.459027] usb 1-1.5.3: New USB device found, idVendor=1902, idProduct=3232, bcdDevice= 1.00
[57332.459039] usb 1-1.5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[57332.459049] usb 1-1.5.3: Product: GENERAL - UVC
[57332.459058] usb 1-1.5.3: Manufacturer: Generic
[57332.474068] uvcvideo: Found UVC 1.00 device GENERAL - UVC (1902:3232)
[57332.483677] uvcvideo 1-1.5.3:1.0: Entity type for entity Processing 5 was not initialized!
[57332.483694] uvcvideo 1-1.5.3:1.0: Entity type for entity Selector 4 was not initialized!
[57332.483706] uvcvideo 1-1.5.3:1.0: Entity type for entity Camera 1 was not initialized!
[57332.484240] input: GENERAL - UVC : GENERAL - UVC as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.3/1-1.5.3:1.0/input/input13
[57333.210214] usb-storage 1-1.5.3:1.4: USB Mass Storage device detected
[57333.212803] scsi host0: usb-storage 1-1.5.3:1.4
[57333.298285] usbcore: registered new interface driver uas
[57334.217253] scsi 0:0:0:0: Direct-Access Generic Mass-Storage 1.13 PQ: 0 ANSI: 4
[57334.225792] sd 0:0:0:0: [sda] Attached SCSI removable disk
[57334.242570] sd 0:0:0:0: Attached scsi generic sg0 type 0
[57414.045658] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.046657] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.047396] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.048664] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.049528] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.053148] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57414.053766] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57548.767639] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57548.774000] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.244782] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.246033] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.255850] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.257653] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.258637] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.266562] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
[57657.267571] uvcvideo: Failed to query (130) UVC probe control : -32 (exp. 26).
pi@raspberrypi:~ $
Any help would be greatly appreciated.
6by9
Re: What am I doing wrong?
Tue Jun 30, 2020 7:15 pm
No, 9 video device nodes, not 9 cameras.
UVC (USB Video Class) devices now support producing both video and metadata. Doing so requires two video device nodes.
/dev/video10 is the memory-to-memory video decoder.
/dev/video11 is the memory-to-memory video encoder.
/dev/video12 is the memory-to-memory video processor (scaling and format conversion).
Most likely you'll be wanting /dev/video0, 2, and 4 as the devices producing images from your cameras.
What software are you trying to use to view the cameras?
Howdoyoudo?
Sat Jul 04, 2020 9:13 am
pi@raspberrypi:~ $ ls -1 /dev/v4l/by-id/
usb-GENERAL_GENERAL_-_UVC-video-index0
usb-GENERAL_GENERAL_-_UVC-video-index1
found em'
Now how do you get em' to work?
Howdoyoudo?
Sat Jul 04, 2020 9:23 am
Bus 001 Device 009: ID 1b3f:2202 Generalplus Technology Inc.
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x1b3f Generalplus Technology Inc.
idProduct 0x2202
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0142
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 2
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
bInterfaceProtocol 0
iInterface 2
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 0x0039
dwClockFrequency 6.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 2
bmControls 0x00000000
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 5
iTerminal 4
bLength 7
bDescriptorType 36
bDescriptorSubtype 4 (SELECTOR_UNIT)
bUnitID 4
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 5
bSourceID 4
wMaxMultiplier 0
bControlSize 2
bmControls 0x0000013f
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
Backlight Compensation
iProcessing 0
bmVideoStandards 0x00
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Video Streaming
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 0x003f
bEndPointAddress 133
bmInfo 0
bTerminalLink 3
bStillCaptureMethod 1
bTriggerSupport 1
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 0
bLength 11
bDescriptorType 36
bDescriptorSubtype 6 (FORMAT_MJPEG)
bFormatIndex 1
bNumFrameDescriptors 1
bFlags 1
Fixed-size samples: Yes
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 1 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 38
bDescriptorType 36
bDescriptorSubtype 7 (FRAME_MJPEG)
bFrameIndex 1
bmCapabilities 0x01
Still image supported
wWidth 1280
wHeight 720
dwMinBitRate 912384
dwMaxBitRate 912384
dwMaxVideoFrameBufferSize 1843200
dwDefaultFrameInterval 333333
bFrameIntervalType 0
dwMinFrameInterval 333333
dwMaxFrameInterval 333333
dwFrameIntervalStep 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0100 1x 256 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 1
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 0
iFunction 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
iInterface 4
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bcdADC 1.00
wTotalLength 0x0026
bInCollection 1
baInterfaceNr(0) 3
bLength 12
bDescriptorType 36
bTerminalID 3
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 1
wChannelConfig 0x0000
iChannelNames 0
iTerminal 0
bLength 8
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 5
bSourceID 3
bControlSize 1
bmaControls(0) 0x03
Mute Control
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 4
bAssocTerminal 0
bSourceID 5
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 4
bDelay 1 frames
wFormatTag 0x0001 PCM
bLength 11
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 1
bSubframeSize 2
bBitResolution 16
bSamFreqType 1 Discrete
tSamFreq[ 0] 32000
bLength 9
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bRefresh 0
bSynchAddress 0
AudioStreaming Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
Bus 001 Device 008: ID 1b3f:2202 Generalplus Technology Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceSubClass 2
bMaxPacketSize0 64
idProduct 0x2202
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0142
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionProtocol 0
iFunction 2
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 2
bLength 13
bDescriptorType 36
bcdUVC 1.00
wTotalLength 0x0039
bInCollection 1
baInterfaceNr( 0) 1
bLength 17
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
iTerminal 0
bControlSize 2
bLength 9
bDescriptorType 36
bTerminalID 3
bAssocTerminal 0
bSourceID 5
iTerminal 4
bLength 7
bDescriptorType 36
bUnitID 4
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bUnitID 5
bSourceID 4
wMaxMultiplier 0
bControlSize 2
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
iProcessing 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 14
bDescriptorType 36
bNumFormats 1
wTotalLength 0x003f
bmInfo 0
bTerminalLink 3
bTriggerSupport 1
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 0
bLength 11
bDescriptorType 36
bFormatIndex 1
bFlags 1
bAspectRatioX 0
bAspectRatioY 0
Field 1 first: No
bCopyProtect 0
bLength 38
bDescriptorType 36
bFrameIndex 1
bmCapabilities 0x01
wWidth 1280
wHeight 720
dwMinBitRate 912384
dwMaxBitRate 912384
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 2
bFunctionSubClass 0
bFunctionProtocol 0
iFunction 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 4
bLength 9
bDescriptorType 36
bcdADC 1.00
wTotalLength 0x0026
bInCollection 1
baInterfaceNr(0) 3
bLength 12
bDescriptorType 36
bTerminalID 3
bAssocTerminal 0
bNrChannels 1
iChannelNames 0
iTerminal 0
bLength 8
bDescriptorType 36
bUnitID 5
bSourceID 3
bControlSize 1
bmaControls(0) 0x03
Mute Control
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bTerminalID 4
bAssocTerminal 0
bSourceID 5
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 4
bDelay 1 frames
bLength 11
bDescriptorType 36
bNrChannels 1
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 32000
bLength 9
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 4
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x00
wLockDelay 0x0000
6by9
Sat Jul 04, 2020 11:30 am
Try qv4l2 or similar.
Howdoyoudo?
Sun Jul 05, 2020 9:16 pm
not to sure what this means, As I am a complete noob and just trying to understand
Howdoyoudo?
Mon Jul 06, 2020 2:19 am
ok I tried
#!/bin/bash
qv4l2 --device=/dev/video0
and got
22:18:33: This is Geany 1.33.
22:18:33: Failed to load one or more session files.
22:18:33: File /home/pi/Desktop/v4 opened(1).
