manu974
How to install clementine ??
Sat Jul 27, 2019 9:17 pm
Hi, to be honest, I'm a bit of a noob on raspbian ...
For years I have a trick that works on my pc, winamp stream and play music, controlled via the pc and/or an android application that makes me a remote control, I relays the whole thing with a FM emitter that sends on FM radio at home.
The trouble, I must have this pc always on.
So I would like to have the same config on a pi3 +, I thought of Clementine and his Android remote.
But, I have been to see several tutorials and I can not install clementine, I always have error messages.
(like here: https: //github.com/clementine-player/Clementine/wiki/Clementine-on-Raspberry-Pi)
if anyone could explain to me how to install it would be very nice.
I am of course open to any other idea (local music player and stream with android remote control).
I already try VLC but it's but it is unnecessarily complicated to do so little (and graphically awful)
Thank you in advance.
Manu.
(sorry for my English, I'm a french speaking guy)
jdonald
Re: How to install clementine ??
Tue Jul 30, 2019 6:44 pm
Yeah, you won't get very far trying to install the Jessie package mentioned in the README, and building from source apparently requires a bazillion dependencies.
Buster: According to this link, Clementine is still available for aarch64 but no longer for armhf.
If you are running Raspbian Stretch, just do:
sudo apt update
sudo apt install clementine
If you're already on Buster, often it's still possible to install old Stretch packages if their dependencies don't have hard conflicts. Edit /etc/apt/sources.list and add this line :
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Then proceed to with the earlier two commands. That worked for me.
Note: Including Stretch packages on Buster does break at least one rule that can potentially lead to a FrankenDebian, so make sure to pay attention to APT's output.
rod2k
Tue Dec 03, 2019 6:06 pm
I recently discover Clementine, and as owner of Rpi B+, the first think crossed my mind was installing Clementine in my rpi and control my music library remotely using Android app, I am using my rpi headless for almost everything
so, I think i already have the answer, but i will ask anyway, Clementine require a Desktop Environmente AKA Pixel, running to compile on rpi?
there is another way/software to remotely control (and make offline libraries in your android) like Clementine does?
