Depends what you are doing, and how accurate the timing needs to be.
You might be able to do live parallel steams from a VLC rtsp server, and hope the buffers stay relatively well matched.
Due to networking and gpu-decoder Latency, the playback mismatch will be difficult to sync up.
There are also scripts people have tried to do a "play all" on remote interfaces for cvlc
https://github.com/Syncplay/syncplay/
https://sourceforge.net/projects/vlcvideowallcon/
Don't know anyone who tried this (I also tend to avoid macro embedded stuff), so YMMV
I would personally look at running a concurrent cluster administration shell like Pssh, and statically assign the dhcp ipv4 leases on your router:
sudo apt-get install python-pip
sudo pip install pssh
cat > ~/host_worker_list.ipv4
192.168.0.10:22
192.168.0.11:22
192.168.0.12:22
192.168.0.13:22
192.168.0.14:22
pssh --hosts ~/host_worker_list.ipv4 -t 30 --user pi -A -i "vlc -I http --fullscreen --no-video-title --http-password testing --http-user guest "
Then write a simple Lua scripting tool if you want more from local file playback:
https://forum.videolan.org/viewforum.php?f=29
External sync inputs allow frame timing accuracy to avoid camera banding in the analog signal days, but many people now just use multi-port video cards in high-refresh rate modes (NVIDIA 4 port pci cards with hardware media decoders is $180.)
Cheers,
J
