AndrewJohnson
Re: Pi Presents: Beta of a major upgrade now available
Fri May 12, 2017 8:24 pm
In case of use to anyone, you can have a look at a project I recently finalised (all free stuff!!!) using links in this post:
viewtopic.php?f=35&t=182502
You can adapt the python code I wrote to do what you want, fairly easily, I hope!
Paul_T
Mon Jun 19, 2017 10:22 am
Hi Ken.
Just started to look at your great program, I have used Arduinos in the past so just getting to grips with Pi (now I've retired).
I am working as a volunteer for the Solent Sky Museum in Southampton and we have several projects that Pi Presents will be great for, if I can get it all working!
Ok so my question is that I need to control an NEC projector on the serial port so that it turns on with the Pi and off at the end of the day. Input select is not a problem is there a way the GPIO can control the serial port? Its the usual 9600,8,n,1. In the past I have 'hacked' the remote control and used the IR to do this, but serial control via Pi Presents would be good any clues or tips would be appreciated.
Paul.
Jake1938
Thu Dec 21, 2017 7:04 pm
Hey Ken,
Love the software, thanks for all your hard work! I work at a museum and we are trying to implement a "spatial" media player, occupying a whole wall and utilizing capacitive triggers hidden under vinyl text.
The capacitive triggers simply emulate keyboard buttons. Here is my dilemma: I need each key to correspond to a specific video. When a key is pressed, it should end the current video and play the video corresponding to the key press. I have set it up so there are three shows, each with a single video track. The shows are toggled with numeric keys 1, 2, and 3. I can bring up each show with the corresponding key press, but I cannot figure out how to end the previous show. Is this feature supported? Alternatively I could start a show with a key hold, and end it when the key is released, but I am not sure how I would implement that either...
I really appreciate the help and the amazing software, it has made my job much easier!
Best, Jake
andygc
Tue Jan 16, 2018 9:29 am
Dear Ken
Thank you for developing this system.
Azizar wrote:
Tue Oct 29, 2013 8:14 pm
I edited /etc/default/unclutter, adding
-grab
and
-noevents
That seemed to do the trick.
I'm working on touch screen presentations for my local museum and wanted to get rid of the cursor. I made these changes to /etc/default/unclutter but it made no noticeable difference. I searched for ways to remove the cursor and found this in the StackExchange Raspberry Pi forum at https://raspberrypi.stackexchange.com/q ... y-pi/69180
I simply added a nocursor option as follows in the file (/etc/lightdm/lightdm.conf)
xserver-command = X -nocursor
and it worked as it should. No cursor is displayed whatsoever.
That line is in the [Seat:*] section of lightdm.conf. I edited /etc/default/unclutter to stop unclutter from running.
START_UNCLUTTER="false"
I agree with the poster of that comment - No cursor is displayed whatsoever. Of course, you can't do this if you want to use a mouse while developing a presentation on a stand-alone Pi, but I'm using VNC Viewer, so the visibility of the Pi cursor doesn't matter.
Andy
andygc
Sat Jan 20, 2018 10:39 am
Following on from my last comment, I've now removed unclutter from my installation, and to get rid of the 'not found' error message in the terminal window when I start PiPresents, I've edited pipresents.py to comment out the line that calls unclutter
#os.system('unclutter &')
Who is online
Users browsing this forum: No registered users and 5 guests
