raspberrypibeginer
robots
Sat Feb 07, 2015 2:58 pm
Hi,one question,can i use a. LED as a 1n4007 diode
Re: robots
Sat Feb 07, 2015 3:13 pm
Maybe, it depends what voltage/current level you're running in that part of your circuit. It's a little unorthodox but it is a diode.
raspberrypibeginer
Re: robots
Sat Feb 07, 2015 4:34 pm
It is 5v, because im using a 555 timer
Re: robots
Sat Feb 07, 2015 5:16 pm
raspberrypibeginer wrote:It is 5v, because im using a 555 timer
Should be OK. I was winking LEDs with 555s thirty-five years ago.
Re: robots
Sat Feb 07, 2015 5:23 pm
Can you show or give a link to the circuit you are building and say where you are thinking about putting the LED?
raspberrypibeginer
Re: robots
Sat Feb 07, 2015 7:07 pm
Find on google Yet Another Simple PWM
Re: robots
Sun Feb 08, 2015 11:55 am
raspberrypibeginer wrote:Image
You can't replace a zener diode with an LED.
Re: robots
Mon Feb 09, 2015 4:56 am
DougieLawson wrote:You can't replace a zener diode with an LED.
It isn't a zener diode. They've used the wrong symbol on the schematic (I've seen this done other places too. Not good!).
The diode used in the example is a IN4007, but pretty much any general purpose diode will do. The LED may work - I'm not sure if the voltage drop across it will be too high. I was worried that as a 1N4007 was mentioned it might have needed to take more current than an LED can handle, but that's not the case.
