garyk1968
Re: DS18B20 and 30-Jan firmware
Sat Jun 06, 2015 9:50 am
Just as an update to my issue I actually have nothing listed in /sys/bus/w1/devices/, not even w1_bus_master1. I believe this should at least be there even if there are no temp sensors attached, is that correct?
jrachev
Sat Oct 31, 2015 7:41 pm
Did anybody find a solution for this problem about not seening the 28-* directory?
I did some rewiring and upgrades but still no success. Only those diretories 00-* that changes their names
lumpi1982
Wed Nov 11, 2015 9:16 pm
the same is true for me, double checked every wiring, should be everything correct.
lumpi1982
Wed Nov 11, 2015 9:20 pm
For me the same is true, cannot see my sensors:
here is my dmesg output:
[    4.934801] w1-gpio [email protected]: gpio pin 4, external pullup pin -1, parasitic power 0
[    4.934858] w1_add_master_device: set_pullup requires write_byte or touch_bit, disabling
[    4.955434] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    5.264726] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.383840] random: nonblocking pool is initialized
[    5.496200] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    5.496803] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.570519] usbcore: registered new interface driver rtl8192cu
[    6.008863] systemd-journald[108]: Received request to flush runtime journal from PID 1
[    6.236987] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.895025] cfg80211: Calling CRDA to update world regulatory domain
[    6.977957] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[    8.383366] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   10.043211] cfg80211: Calling CRDA to update world regulatory domain
[   13.193250] cfg80211: Calling CRDA to update world regulatory domain
[   16.002622] Adding 102396k swap on /var/swap.  Priority:-1 extents:5 across:573436k SSFS
[   16.343399] cfg80211: Calling CRDA to update world regulatory domain
[   19.493296] cfg80211: Calling CRDA to update world regulatory domain
[   22.643308] cfg80211: Calling CRDA to update world regulatory domain
[   25.793342] cfg80211: Calling CRDA to update world regulatory domain
[   28.943275] cfg80211: Calling CRDA to update world regulatory domain
[   32.093379] cfg80211: Calling CRDA to update world regulatory domain
[   35.243420] cfg80211: Calling CRDA to update world regulatory domain
[   38.393437] cfg80211: Calling CRDA to update world regulatory domain
[   41.543420] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
[   54.483053] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
and here the content of my w1 directory:
[email protected] /sys/bus/w1/devices $ ll
total 0
drwxr-xr-x 2 root root 0 Nov 11 21:20 .
drwxr-xr-x 4 root root 0 Nov 11 21:19 ..
lrwxrwxrwx 1 root root 0 Nov 11 21:20 00-400000000000 -> ../../../devices/w1_bus_master1/00-400000000000
lrwxrwxrwx 1 root root 0 Nov 11 21:19 00-800000000000 -> ../../../devices/w1_bus_master1/00-800000000000
lrwxrwxrwx 1 root root 0 Nov 11 21:19 w1_bus_master1 -> ../../../devices/w1_bus_master1
jrachev
Thu Nov 12, 2015 8:34 am
Hi all,
I managed to solve my problem with not seeing the 28-###### directory. Problem was bad wiring.
Now it works like a charm :)
Lwells07
Sat Dec 05, 2015 1:37 am
I have the same issue.
I was running an old kernel and have recently upgraded to raspbian 4.1.7+
sudo modprobe w1-gpio;
sudo modprobe w1-therm;
ls /sys/bus/w1/devices/
00-800000000000
w1_bus_master1
dmesg shows:
This tells me my wiring is right the device just isn't being recognized or in the right 'family'.
Any thoughts?
Help would be greatly appreciated!
Sun Dec 06, 2015 3:41 pm
It's not done that way any more.
Read /boot/overlays/README and add a dtoverlay line to your config.txt.
This is a doctor free zone.
brianc007
Thu Jan 07, 2016 9:32 pm
I am completely new to the pi. I got a pi 2 recently and have carried out several basic tasks with the breadboard and programming with no problems. however I have been trying to set up a DS18B20 temp sensor without any success at all. I have tried the config.txt revisions and rewired it several times in different positions on the breadboard but still nothing. When I list devices nothing at all is shown. Is this a wiring fault? I have read that some sensors have the wrong coloured wiring- is this likely. Anybody got any other ideas?
Dave31
Mon Jan 11, 2016 2:32 pm
I have the same problem. I've tried 2 DS18B20 sensors and all of the many solutions(?) found on line. All with no success, the sensors are not found. I am also using a pi 2.
Carrolls3
Mon Feb 08, 2016 9:04 pm
I am also having issues getting the Raspberry Pi to recognize the DS18B20 sensor. I have read multiple posts, checked my wiring over and over, updated the config.txt file with suggested entries, used multiple sensors and resistors, but still only see a "w1_bus_master1" entry when checking the /sys/bus/w1/devices/ directory following the issue of "sudo modprobe w1-gpio" and "sudo mod probe w1-therm" commands. Firmware and OS are at most recent versions on my Pi B. At my wits end. Any suggestions?
wynneth
Thu Feb 11, 2016 1:55 am
Just in case anyone else winds up here from Google like I did...
The problem I ran into was that I also use lirc on the same rpi, which requires it's own dtoverlay. I had tried to add the w1-gpio to the same dtoverlay line in /boot/config.txt and it only loaded the first one (lirc). The fix was to use a separate dtoverlay line for each.
dtoverlay=lirc-rpi,gpio_out_pin=22,gpio_in_pin=23
dtoverlay=w1-gpio,gpiopin=4
povniouk
Wed Mar 01, 2017 9:56 am
hi,
i am running into the same problem... Is this post closed without answer?
Wed Mar 01, 2017 12:50 pm
This thread is superseded by the 2017-02-16 Raspbian release.
Try using that with the right overlay (plain 1-wire or 1-wire with parasitic power) defined in your /boot/config.txt
vinoj wijesundara
Sat Apr 06, 2019 7:39 am
Pls check the pullup resistor in between sensor data pin and supply voltage. if you did not use 4.7Kohm resister. you will not get the sensor address.
secondly, check config file using sudo nano /boot/config.txt you have to write dtoverlay = w1-gpio
hope you will ok.
