riffraff
Has anyone had success with "visolate"???
Thu Jan 29, 2015 5:11 am
I'm in the process of putting together a small CNC for printed circuits. I had high hopes to use visolate to produce Voronoi isolation pcb's, but I haven't had any luck getting it running.
It is, after all, in the raspbian repository, but after further study of its inner workings I'm not even even sure it can run on the Pi.
I was just curious if anyone else had looked at this package.
blamarpa
Re: Has anyone had success with "visolate"???
Wed Oct 12, 2016 11:37 am
I have got it runnig today.
openjdk-6-jre are no present in repositories so Install icedtea-next package that replaces it.
Cant run it using menu - electronics - visolate but callíng it with:
java  -jar /usr/share/visolate/Visolate.jar
does.
Hope this helps. I dont know how to use it (jet) so cant tell you more.
blamarpa
Wed Oct 12, 2016 1:41 pm
Just now, downloaded:
https://github.com/Traumflug/Visolate/b ... -3.1.1.jar
in /usr/share/visolate
and run:
java -jar /usr/share/visolate/visolate-3.1.1.jar
Seen to run too.
