pingu512
Re: Weather Station now running
Mon Jan 06, 2014 7:29 pm
Hi Naill
I accept that I could have explained the location of files better. This all started with just the setup of the connection, but has expanded as I get more questions. I had been reluctant to duplicate the work done by Jim Easterbrook unless it was raspberry specific, but further questions have resulted in what I have so far.
The command
python -m pywws.LogData -vvv ~/weather/data
is first used to create the weather.ini file, so it appears to do nothing, but it does create a blank one. Some users may want then to directly edit it with their information including the location of output files, or you can down load my example.
I would need more information on the output produced from the process command.
Try
python -m pywws.Process ~/weather/data > outputfile.txt
This will direct the screen output to a file called outputfile.txt which you can then view or send your PC.
Niall101
Tue Jan 07, 2014 9:32 am
Hi again,
Thanks for the reply. In fact, last night I spent another few hours getting more acquanted with the Pi (and, obviously, Linux). I installed FileZilla on a PC and tried, unsuccessfully, to make an FTP connection to the Pi. Google then helped me install vsftpd onto the Pi (although the tutorial I was following was not without its own problems!).
I have now at least been able to bring a whole bunch of files into the PC where I was happier to look at them, without fear of 'breaking' the Pi ;) In fact, I was even able to see in, the bash log, where I had made the typos that gave me all the problems when I was trying to use the wget commands.
I did try your suggestion of capturing the console output (of the pywws.LogData and pywws.Process commands), but all I seemed to get was a blank file (so blank that it did not even appear on the FileZilla 'remote' directory listing view, despite being shown by an ls command - even the more command, applied to the output file, showed nothing).
However, my brain was now overheating and was beginning to dribble out of my ears by this time - so I will start again tonight (I even found the code listing for the pywws.Process command, and I will try and see how the error messages correspond to the actual Python code).
I'll be in touch again.
Cheers,
Niall
Scatch-built BBC B in 82: blank PCB+scavenged plastics& PSU. Sinclair Calc & ZX81 kits in 74&82. PONG (AY-3-8500) in 77. 1st PC in 89: 386/25+387&10MbHDD. Have previewed pictures with my PiCam. I'll maybe save one next week (new to Linux)!
henkg
Wed Jan 08, 2014 2:06 pm
Searched a lot. Did not find it (yes, I am a linux novice)
Before making a backup of pywws data, I want to stop pywws temporarily.
How do I stop (and start) pywws on a running pi?
My RPI+PYWWS weather site: http://henkg.dyndns.org:82/
Niall101
Thu Jan 09, 2014 10:48 am
Hi Henk,
Remembering that I am also a total Linux newbie - assuming that you do not have any scheduled tasks being triggered by CRON, I don't see that there would be anything to actually 'stop'.
However, if CRON is controlling processes in the background, then - presumably - there must be a method of 'suspending' these whilst you transfer the data that you are after.
Continuing my own trials - I ended up having to revert to an earlier SD image (one that I had, fortunately, saved just after my first run of the LogData process). My attempts (using a tutorial from instructables.com) to install an FTP server ended up 'wrecking' my running image - to the extent that, when logging on as pi, I was being left at a totally different level in the directory structure. Without adequate Linux experience, and despite having taken copious notes, I had no idea how to get back to where I had started from - other than a complete SD card re-image :x
I still can't get the following to work:
python -m pywws.LogData ~/weather/data > logged_output.txt
I always seem to end up with a completely 'empty' output file, despite seeing all the console output appearing on-screen (running 'headless' with Putty/SSH).
Also, LogData takes a LONG time to complete - often appearing to crash irrevocably, where the only solution is to power-cycle the Pi itself. If LogData does work, it is liberally scattered with 41-second and 5.8 second pauses. Why does this happen?
Cheers,
Niall
pingu512
Fri Apr 11, 2014 7:33 pm
Anyone connected a Ambient WS-2090 weather station to a pi running pywws. What's the ws = setting in weather.ini?
pingu512
Fri Sep 05, 2014 7:35 pm
New and simplified tutorial at http://www.weather.dragontail.co.uk that now uses the python USB library. I have also updated the SD card image with the latest setup and 'wheezy".
Enjoy
Robert G
Sat Feb 14, 2015 9:34 pm
Hi there,
looking for a bit of advise. Im trying to set up my pi with a maplin wireless weather station ref N96FY. Ive unstalled wheezy and pywws and installed the usb module but im still getting the following error
[email protected] ~ $ sudo python -m pywws.TestWeatherStation
File "/usr/lib/python2.7/runpy.py", line 162, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/usr/local/lib/python2.7/dist-packages/pywws/TestWeatherStation.py", line 59, in <module>
from . import WeatherStation
File "/usr/local/lib/python2.7/dist-packages/pywws/WeatherStation.py", line 96, in <module>
raise ImportError('No USB library found')
ImportError: No USB library found
I am a total novise when it comes to programming so any help would be gratefully received.
pingu512
Sun Feb 15, 2015 4:50 pm
Looks like python usb is not loaded
see
http://www.weather.dragontail.co.uk/ind ... tion_setup
Robert G
Sun Feb 15, 2015 6:27 pm
Thanks a million - now for the next steps.
farrpau
Thu Mar 12, 2015 10:25 pm
Robert G wrote:Hi there,
was having exact same problem found my mistake in this instruction, between the add and change is a straight line (shift-\) not a backslash (\) as i entered it.
sudo nano /etc/udev/rules.d/39-weather-station.rules
Add the following lines changing the idVendor and idProduct if required
ACTION!="add|change", GOTO="station_end"
SUBSYSTEM=="usb", ATTRS{idVendor}=="1941", ATTRS{idProduct}=="8021", GROUP="weather"
LABEL="station_end"
