Controller with inputs and outputs
Posted: Wed Dec 24, 2014 7:42 am
I need to control 36 devices over digital outputs (or relays) and also, I need to get digital signal from it (pressed button), so I need 36 more inputs. I would like to control it from RPI.
Can you suggest any of your devices for that? It is ok, if I will connect several relay stations (controllers) to RPI. Also, should be good solution to connect it over TCP/IP.
So far I found:
http://www.moxa.com/product/ioLogik_E1212.htm
But it is really expensive..
I prefer to buy it as product..
Any suggestions?
Thank you
Lukas
So far I found:
Any suggestions?
Thank you
Lukas
