Jossep
Logging data from RPi
Sat Nov 22, 2014 1:23 pm
Hello, I'm a last-year engineering student.
For my thesis I need to build an (electric) bike equipped with all kinds of sensors.
It is the intention to go for a ride and display the desired data (steering angle, power,...) on a tablet / smartphone.
After lots of searching on the web, i found a possible solution:
I have to work with an Arduino and a Raspberry Pi.
I need to connect the sensors to an Arduino, Arduino sends the data to the Raspberry Pi that stores the data.
The problem is that i don't know where to store the data.
I've read a lot about storing it on a database and control it via phpMyAdmin (or something similar).
But of course i have no wifi or ethernet connection.
So my question is: Where/how do I store the data I collect during my trip?
joan
Re: Logging data from RPi
Sat Nov 22, 2014 2:30 pm
Given that you have no external connectivity you'll have to store the data in a file on the Pi. The obvious location is the Pi's SD card (which must be present for the Pi to boot/run) or a USB flash memory dongle.
Jossep
Sun Nov 23, 2014 9:15 pm
Thank you.
Do you think I can realise this project without the Arduino?
What is the benefit of the Arduino in this project?
joan
Sun Nov 23, 2014 9:23 pm
Whether an Arduino is needed/useful depends on the sensors you plan to connect. For instance an Arduino can handle analogue sensors, whereas a Pi would need to have additional components to handle an analogue sensor.
Gavinmc42
Tue Nov 25, 2014 3:21 am
Use i2c sensors
Lots around of them around
LTC2945 for voltage/current/power
TMP112 temperature
Accel/Gyro/Compass etc
Break out PCBs from Adafruit/Sparkfun/Seeed if you cannot make your own.
Use simple Python scripts to read i2c sensors and log data to a file on SD or USB stick
I'm dancing on Rainbows.
Jossep
Mon Dec 01, 2014 4:07 pm
Thank you!
The desire to log the data to a smartphone or tablet is rejected.
It is enough to check the data after the bicycle tour.
I am trying things out with an accelerometer/gyroscope: MPU6050
How does the arduino send the data to the rpi?
Will a simple USB connenction between the rpi and arduino work?
The rpi will be powered from an external battery (9V).
When the rpi and arduino are connected via USB, does the rpi correctly power the Arduino?
joan
Mon Dec 01, 2014 4:16 pm
You can talk to a MPU6050 directly from the Pi, you don't need an Arduino.
The Pi requires 5V power. If you power the Pi from a 9V battery you will destroy the Pi.
asandford
Mon Dec 01, 2014 7:25 pm
Jossep wrote: How does the arduino send the data to the rpi?
You can communicate serially over USB, and the Arduino will appear as a tty device in /dev (exact name depends on model) on the pi.
Jossep wrote: The rpi will be powered from an external battery (9V).
If you power the Arduino from the 9v battery, the regulated 5v output can power the pi.
yv1hx
Location: Now an expatriate, originally from Zulia, Venezuela
Contact: Website Skype
Sat Dec 06, 2014 4:25 pm
I will go thought direct the option using the RPi, unless you have a very specific sensor that requires the Arduino for interact with others devices.
As some other people has told you, the RPi cannot be powered directly from a 9volts battery, you need some type of voltage regulator, also I'm unsure if the 9volt battery will last more of a few minutes while powering the Rpi.
If you need the barometric pressure/height/air temperature sensing, the BMP180 breakout board from Adafruit is a great option.
In that case I would recommend you use a portable power bank (Like these: http://www.amazon.com/Power-Chain-Smart ... power+bank), the capacity will be restricted to your budget and/or endurance time.
Some people find overkill the use of Mysql and related databases in the Rpi, I'm not an expert on that, but in all of my projects I always use the plain text files for storing the data recovered form the physical world, in this way I can ingest the data easily in another systems.
Marco-Luis
Telecom Specialist (Now Available for Hire!)
http://www.meteoven.org
http://twitter.com/yv1hx
