Page 2 of 2
Re: Controlling a 7 segment 4 digit display with a Raspberry
Posted: Sun May 14, 2017 3:06 pm
by neonj
Hi blachanc,
Thanks for the ramdisk code.
Can you please tell me how do I exit the python script after a set number of seconds.
Regards
Posted: Sun May 14, 2017 3:10 pm
by neonj
blachanc wrote:Well,
I learned something(correct me if I am wrong): a python script does not read the updated env variable value in a terminal. It will keep the values it reads when it is invoked.
SO I reverted back to my second idea of using a file on a ramdisk for communication(and it is working). I still wonder if there would be a better way.
this is the main display loop (display daemon):
display.py
#!/usr/bin/python
# Bert's code re-written for common anode LED arrays.
#blachanc: used dougie's code and added external data input in ramdisk
import RPi.GPIO as GPIO
import time
import sys
GPIO.setmode(GPIO.BCM)
#GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(7, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
#LED pin == GPIO == segment / digit
# 11     ==  24  == a
# 07     ==  12  == b
# 04     ==  19  == c
# 02     ==  21  == d
# 01     ==  23  == e
# 10     ==  22  == f
# 05     ==  15  == g
# 03     ==  11  == dp
segments = (24,12,19,21,23,22,15,11)
for segment in segments:
  GPIO.setup(segment, GPIO.OUT)
  GPIO.output(segment, 1)
# 12     ==  26  == digit 1
# 09     ==  18  == digit 2
# 08     ==  16  == digit 3
# 06     ==  13  == digit 4
digits = (26,18,16,13)
for digit in digits:
  GPIO.setup(digit, GPIO.OUT)
  GPIO.output(digit, 0)
charactere = {' ':(1,1,1,1,1,1,1),
'0':(0,0,0,0,0,0,1),
'1':(1,0,0,1,1,1,1),
'2':(0,0,1,0,0,1,0),
'3':(0,0,0,0,1,1,0),
'4':(1,0,0,1,1,0,0),
'5':(0,1,0,0,1,0,0),
'6':(0,1,0,0,0,0,0),
'7':(0,0,0,1,1,1,1),
'8':(0,0,0,0,0,0,0),
'9':(0,0,0,0,1,0,0)}
counter=100000
# use a file on ramdisk to get the data to be displayed
# bash commands passed in terminal:
# sudo mkdir /mnt/ramdisk
# sudo mount -t tmpfs -o size=128K tmpfs /mnt/ramdisk
# sudo chown pi:pi /mnt/ramdisk
# echo "1235" > /mnt/ramdisk/display.dat
def get_data_to_display():
    txt=open("/mnt/ramdisk/display.dat")
    new_string = str(txt.readline())
    txt.close()
    new_string=new_string.rstrip()
	# buf with 0 if less than 4 char
    new_string= str(new_string).rjust(4,"0")
	# limit to 4 chars
    new_string= new_string[0:4]
    return new_string
# main loop
try:
  while True:
	# First we only update the data to display each x loops
    counter +=1
    if (counter > 50):
       counter = 0
       new_string = get_data_to_display()
# for debug only       print  new_string
       data_to_display = new_string
    for digit in range(4):
      for loop in range(0,7):
        GPIO.output(segments[loop], charactere[data_to_display[digit]][loop])
      GPIO.output(digits[digit], 1)
      time.sleep(0.001)
      GPIO.output(digits[digit], 0)
except KeyboardInterrupt:
  GPIO.cleanup()
and this is the data being feed to the display (scrolling numbers) for proof of concept.
feedata.py:
#!/usr/bin/python
import time
import sys
counter = 0
data_to_display= "    "
# main loop
try:
  while True:
    counter +=1
    if (counter > 9):
       counter = 0
     # shift the data to be displayed
    data_to_display= data_to_display[1] + data_to_display[2] + data_to_display[3]+ (str(counter))[0]
    txt=open("/mnt/ramdisk/display.dat", "w" )
    txt.write(data_to_display)
    txt.close()
# For debug only    print data_to_display
    time.sleep(.5)
  exit()
Hi blachanc,
Thanks for the nice code, just what I needed.
Can you please tell how to cleanly exit this code after a set number of seconds.
I'm just a beginner so pardon my novice question.
Regards
