Setting gpio pins on boot
Posted: Tue Nov 11, 2014 8:24 am
Hi, I recently bought a relay card similar to this :
http://www.ebay.co.uk/itm/8-Channel-5V- ... 417979a25d
And I was a bit miffed to discover that the Pi was turning on some of the relays during boot.
To solve this problem it is necessary to set the gpio pins during boot. Fortunately this has recently become possible by doing the following :
Update the firmware
And reboot when requested
Install device tree compiler and certificates
Create a dt-blob.dts file
add the following to the file:
exit from the editor
now we install the binary blob into /boot
Now all you need to do is reboot your Pi, and all the relays should be turned off at boot time.
I've attached a zipped copy of the dt-blob.dts file to make things easier
Don't forget gpio pins 2 and 3 are gpio pins 0 and 1 on the version 1 board
I found the info to do this at the following places:
http://www.raspberrypi.org/documentatio ... uration.md
http://www.raspberrypi.org/documentatio ... dating.md#
Hopefully someone will find this useful, as it took me a day to get this working.
Update the firmware
sudo rpi-updateInstall device tree compiler and certificates
sudo apt-get install ca-certificates device-tree-compilerCode: Select all
nano dt-blob.dtsCode: Select all
/dts-v1/;
videocore {
// The following line is for a version 2 board
pins_rev2 {
// For a version 1 board use the following line instead
// pins_rev1 {
// For a B+ board use the following line instead
// pins_bplus {
pin_config {
pin@default {
polarity = "active_high";
termination = "pull_down";
startup_state = "inactive";
function = "input";
}; // pin
// I have rem'd out gpio pins 2 and 3 here, as I am using them for my relays
// If you're not using them you should enable them here
// On a version 1 board this will be pins 0 and 1
//pin@p2 { function = "i2c0"; termination = "pull_up"; }; // I2C 0 SDA
//pin@p3 { function = "i2c0"; termination = "pull_up"; }; // I2C 0 SCL
pin@p5 { function = "output"; termination = "pull_down"; }; // CAM_LED
pin@p6 { function = "output"; termination = "pull_down"; }; // LAN NRESET
pin@p14 { function = "uart0"; termination = "no_pulling"; drive_strength_mA = < 8 >; }; // TX uart0
pin@p15 { function = "uart0"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // RX uart0
pin@p16 { function = "output"; termination = "pull_up"; polarity = "active_low"; }; // activity LED
pin@p21 { function = "output"; termination = "no_pulling"; }; // Camera shutdown
pin@p40 { function = "pwm"; termination = "no_pulling"; drive_strength_mA = < 16 >; }; // Left audio
pin@p45 { function = "pwm"; termination = "no_pulling"; drive_strength_mA = < 16 >; }; // Right audio
pin@p46 { function = "input"; termination = "no_pulling"; }; // Hotplug
pin@p47 { function = "input"; termination = "no_pulling"; }; // SD card detect
pin@p48 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD CLK
pin@p49 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD CMD
pin@p50 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD D0
pin@p51 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD D1
pin@p52 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD D2
pin@p53 { function = "sdcard"; termination = "pull_up"; drive_strength_mA = < 8 >; }; // SD D3
// I am using gpio pins 2, 3, 4, 9, 10, 11, 17, 22, 27 for my relays. Delete any you do not wish to use,
// or change the pin numbers to suit your purposes
// my relay board activates relays when a low signal is applied, so the pins are set with pull_up resistors, and active_high
// if your board activates the relays when a high signal is applied, you need to use pull_down resistors and active_low (I think)
pin@p2 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // FIRST_RELAY
pin@p3 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // SECOND_RELAY
pin@p4 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // THIRD_RELAY
pin@p17 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // FORTH_RELAY
pin@p27 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // FIFTH_RELAY
pin@p22 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // SIXTH_RELAY
pin@p10 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // SEVENTH_RELAY
pin@p9 { function = "output"; termination = "pull_up"; startup_state = "active"; polarity = "active_high"; }; // EIGHTH_RELAY
// end of my settings
}; // pin_config
pin_defines {
pin_define@HDMI_CONTROL_ATTACHED {
type = "internal";
number = <46>;
pin_define@NUM_CAMERAS {
type = "internal";
number = <1>;
pin_define@CAMERA_0_I2C_PORT {
type = "internal";
number = <0>;
pin_define@CAMERA_0_SDA_PIN {
type = "internal";
number = <0>;
pin_define@CAMERA_0_SCL_PIN {
type = "internal";
number = <1>;
pin_define@CAMERA_0_SHUTDOWN {
type = "internal";
number = <21>;
pin_define@CAMERA_0_UNICAM_PORT {
type = "internal";
number = <1>;
pin_define@CAMERA_0_LED {
type = "internal";
number = <5>;
pin_define@FLASH_0_ENABLE {
type = "absent";
pin_define@FLASH_0_INDICATOR {
type = "absent";
pin_define@FLASH_1_ENABLE {
type = "absent";
pin_define@FLASH_1_INDICATOR {
type = "absent";
pin_define@POWER_LOW {
type = "absent";
pin_define@LEDS_DISK_ACTIVITY {
type = "internal";
number = <16>;
pin_define@LAN_RESET {
type = "internal";
number = <6>;
}; // pin_defines
}; // pins
<ctrl> x
yCode: Select all
sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob.dtsI've attached a zipped copy of the dt-blob.dts file to make things easier
