tbd.pi
Triggering from GPIO
Wed Oct 29, 2014 5:18 pm
I have an Audio Fx sound board from Adafruit, and it has 10 channels from which I can trigger sounds. I have a momentary switch hooked up and it works great, I can press the switch, trigger the sound. But now I'm looking to do this from software. If I hook up GPIO #23 (for example) with a wire to the device it will just keep playing the sound file. So, I'm guessing that I need the default of the GPIO pin to be 0v, correct? Or do I need to put something in-between the GPIO and the sound board?
Tarcas
Re: Triggering from GPIO
Thu Oct 30, 2014 1:28 am
I would use a transistor or relay, so that when you trigger that with the GPIO pin, it bridges the same contacts that the switch does. Although, I am a little unclear on the board that you're using. Can you post a link to the spec sheet?
tbd.pi
Thu Oct 30, 2014 2:03 pm
I don't know about a tech sheet, this is the board I am using http://www.adafruit.com/products/2133
tbd.pi
Fri Oct 31, 2014 4:44 am
Seems I don't need anything extra.If I just put a wire to the board and output 0 for about 50ms, that's sufficient to do what I need. Fun, because I spent 3 hours trying to learn about this, got a transistor working, then just thought "what if"..
Now I have about 5 hours until my daughter wakes up and expects "this halloween project" to be together. I wrote my best essays in school the night before, I wonder what I can pull out for halloween to not disappoint a 5 year old?
