marsman2020
I2C 16 Channel PWM/Servo Breakout - Working
Thu Jun 21, 2012 6:45 pm
I have successfully attached an NXP PCA9685 16-channel PWM controller breakout (http://www.adafruit.com/products/815) to my Pi, and used the userspace i2cset command to change the registers around and move a servo.
I used the new armel Debian Wheezy with bootc's 3.2.20 r1 kernel from http://www.bootc.net/projects/raspberry-pi-kernel/
I have to say compared to dealing with the spaghetti code of different Arduino libraries for running I2C, etc, it was very easy. Attach device, modprobe i2c-dev to get userspace i2c interfaces, run i2cdetect to make sure it was showing up on address 0x40, and then set registers by using
i2cset <I2C-BUS> <DEVICE ADDRESS> <REGISTER ADDRESS> <VALUE>
I used a small breadboard power supply (http://www.cutedigi.com/tools/power-sup ... upply.html) to provide 3V3 to the VCC and 5V to the server drive V+ on the breakout board, without taxing Pi's power supply. Tied the ground on the Pi to the ground on the power supply and the breakout board, connected up the SDA and SCL lines, and everything...just worked.
I may write a small python library for the PCA9685, if folks are interested.
Tanga
Re: I2C 16 Channel PWM/Servo Breakout - Working
Fri Jun 22, 2012 7:11 am
Very keen to see where you go with this. The first step towards a pi powered robot. I just ordered this breakout:
http://www.sparkfun.com/products/10616
for another project, so won't be able to use your code if I keep going that way, but I'm keen to read about what you do as robotics is still pretty abstract and difficult to understand. I just ordered one of these robots, however:
http://www.kickstarter.com/projects/arc ... open-robot
and would be keen to see if I can hook it up to the pi for added connection options and processing power. :)
Raspberry Pi (Raspbian) Tutorials by a fellow noob:
http://noobsquared.blogspot.com.au/
marsman2020
Fri Jun 22, 2012 4:32 pm
A fellow makerspace member just did a large (144 channels) PWM driver setup with 3 SPI interface shift register 48 channel PWM drivers, for a massive LED art project.
After watching what was required to make the SPI chips work (and helping a little with getting it running), I decided to go with I2C for the servo application. If I build a rocker bogie mars-rover style robot, there will be a maximum of 10 servos for the driveline and maybe 2 for some other attachments. Electrically and timing-wise I2C is more complicated because of only using 1 wire that the master and the slave pull low/leave high to transmit data, but the userspace tools and python_smbus bindings in Linux seem to be easier to use then SPI devices (mainly because I2C/SMBus is extensively used in computers for sensors)
I do have a SPI LCD backpack also from Adafruit that I want to try, but I need a 3.3V-5V level shifter on the SPI bus to make that work.
marsman2020
Fri Jun 22, 2012 11:21 pm
I'm going to push forward with making a PiBot using this controller.
An early parts list/description. The goal is to keep things inexpensive and use what I have around the house.
Chassis:
<Insert easily available thin plate building material here>
Power:
-1 4-AA battery holder
-1 1-AA battery holder
(NiMH cells vary from 1.4V at startup to 1.1v when they are close to dead. 5 will yield 7V-5.5V)
-1 MIC29300-5.0WT 5V, 3A low-dropout linear regulator (http://www.digikey.com/product-search/e ... 76-1121-Nd)
-1 MIC29310-3.3WT 3V3, 3A low-dropout linear regulator (http://www.digikey.com/scripts/dksearch ... 76-2228-nd)
(The 5V regulator will power the Pi, 4 servos, and the Wifi adapter. The 3V3 regulator will power the PWM controller chip and any other future 3V3 I2C devices)
-5x Eneloop 1800mAh AA NiMH Cells
Mobility:
-4 Continuous Rotation Servos (http://www.pololu.com/catalog/product/1248)
-4 Wheels (http://www.pololu.com/catalog/product/1193)
Communications:
-1 TBD USB wifi adapter on a USB extension cord, with the 5V lines cut and attached to the regulator.
Sensors:
TBD
Control:
-Raspberry Pi
-Adafruit 16 Channel PWM Breakout
seregus
Tue Aug 14, 2012 3:54 pm
I was just about to give up on my idea to use Raspberry as a heart and brain for my robot project, but randomly found your post!
It looks like it's exactly what I needed to make my robot move and even add a servo to move it's camera using Linux, not real-time OS!
If I may ask - did you accomplished writing up some library for controlling the PWM outputs for this board? If you positive on this, is it okay if I'll ask you to share your code? In any case thank you very much for your post - it was very helpfull!
rfincher1
Mon Sep 10, 2012 9:19 pm
There is now a tutorial from Adafruit on connecting their 16 channel pwm board to the Pi:
http://learn.adafruit.com/adafruit-16-c ... pberry-pi/
It has a Python library.
Rick
sgo
Sat Oct 13, 2012 11:06 am
Good Idea !
By experience it may be risky to power the Servo and the controlling logic from the same LDO.
(I already made a project with a simple DC/DC converter + two servo and a microcontroller. The current surge on the servo caused so slight voltage decrease and as such brown out and random code on the microcontroller !)
gideon
Sun Jun 23, 2013 6:09 pm
marsman2020 wrote:I have successfully attached an NXP PCA9685 16-channel PWM controller breakout (http://www.adafruit.com/products/815) to my Pi, and used the userspace i2cset command to change the registers around and move a servo..
Any idea if it would work to control two 5-6v DC motors? The tutorial seems to say it won't?
joerob
Tue Jun 25, 2013 1:31 am
You seem to have some idea how to use I2C. I am presently very confused. There seem to be several Python support libraries. Which one to use? Why? Some of the samples require root permissions to run, which makes no sense to me. Most examples are tied closely to a specific chip such as MCP23008 and lack generality.
You stated:
I have no idea what that means. Where did you start? What library examples did you use?
As to your motor question, the Adafruit board is just a PWM generator. You still need a motor controller chip. You send the PWM to the motor chip along with 2 logic lines for direction and breaking. You could use an MCP23008 or GPIO for the logic. A common work-around employs servos modified for continous rotation. Servos have the motor controller built-in so that PWM alone is sufficient.
Torsten1
Wed Mar 11, 2015 7:15 pm
Hello
can you please explain which values to use for <REGISTER ADDRESS> and <VALUE>
to control a servo ?
BR/Torsten
BMS Doug
Wed Mar 11, 2015 10:38 pm
Hello
BR/Torsten
The easiest method is to use the adafruit libraries
rfincher1 wrote:There is now a tutorial from Adafruit on connecting their 16 channel pwm board to the Pi:
Rick
If you don't want to use the adafruit libraries you can find a full description of the address registers in the datasheet (pages 9 to 13).
Doug.
Torsten1
Thu Mar 12, 2015 1:03 pm
Thank's!
so ok address space for Port 0 is 0x06 0x07 0x08 0x09
first i have to set the MODE1
i2cset -y 2 0x40 0x00 0
Prescale value default is 0x1e.
i looked into some scripts they calculate the prescale like this, so I have done with PHP
$freq = 60;
$prescaleval = 25000000.0;
$prescaleval /= 4096.0;
$prescaleval /= $freq;
$prescaleval -= 1.0;
$prescale = round($prescaleval,0 ,PHP_ROUND_HALF_UP);
$oldmode = 0x1e;
$newmode = ($oldmode & 0x7F) | 0x10;
(NOW PLAN WHY ?)
know set the new prescale
i2cset -y 2 0x40 0x00 $newmode
i2cset -y 2 0x40 0xFE $prescale
i2cset -y 2 0x40 0x00 $oldmode
$neu = $oldmode | 0x80;
i2cset -y 2 0x40 0x00 $neu
so the new prescale mode is 0x65 from i2cget -y 2 0x40 0xFE
example from code https://github.com/kaosat-dev/adafruit- ... ver.coffee
and then set the port 0
i2cset -y 2 0x40 0x06 0
i2cset -y 2 0x40 0x07 0
i2cset -y 2 0x40 0x08 88
i2cset -y 2 0x40 0x09 2
But nothing move ;(
joan
Thu Mar 12, 2015 1:26 pm
Torsten1 wrote:
But nothing move ;(
All sorts of things could be wrong.
A photo and description of your connections may help.
Torsten1
Mon Mar 16, 2015 5:15 pm
Hello again
so it works, but i can only controll 90deg.
By hand I can rotate the servo 180 deg.
Making PCA9685 go to sleep
/usr/sbin/i2cget -y 2 0x40 0
0x00
set sleep bit while preserving other bits and ensuring that restart bit is set to 0 when writing to register
/usr/sbin/i2cset -y 2 0x40 0 16
Setting frequency to 60 Hz. Calcualting prescale value prescale=round( 25000000/(4096 * frequency)) - 1 from frequency as 101(PCA9685 clock is at 25MHz or 25000000 Hz)
/usr/sbin/i2cset -y 2 0x40 254 101
/usr/sbin/i2cset -y 2 0x40 0 0x00
usleep 5000
/usr/sbin/i2cset -y 2 0x40 0 128
Setting Channel 0 PWM on at 0 step, off at 150 step in 0 to 4095 steps at 60 Hz
/usr/sbin/i2cset -y 2 0x40 6 0
/usr/sbin/i2cset -y 2 0x40 7 0
/usr/sbin/i2cset -y 2 0x40 8 150
/usr/sbin/i2cset -y 2 0x40 9 0
Setting Channel 0 PWM on at 3 step, off at 0 step in 0 to 4095 steps at 60 Hz
/usr/sbin/i2cset -y 2 0x40 6 3
/usr/sbin/i2cset -y 2 0x40 8 0
JasonBourne68
Wed Jan 27, 2016 1:21 pm
Should this:
Not be something like this:
Setting Channel 0 PWM on at 0 step, off at 600 step in 0 to 4095 steps at 60 Hz ?
So:
should be:
And:
Should be:
/usr/sbin/i2cset -y 2 0x40 8 600
phpdreams
Tue Feb 28, 2017 4:59 am
I know this is a fairly old post, but some of the info in this thread helped me along the way. I just put together a PHP Class/Package that will control the Adafruit PCA9685 PWM/Servo board quickly and easily. You can get it along with instructions here:
Git Hub: https://github.com/phpdreams/pca9685
Hope it helps!
Bill
