pcanu
Switching Lights On and Off with a timer
Wed Oct 01, 2014 7:01 am
Hello everyone this is my first post on this forum.
What I am looking for is to switch lights on and off using some relay and a timer that simulates takt time.
For example, if the the timer is set to 120 seconds and i press the start button, de light goes on and switches off after 120 seconds.
There must be also some kind of overview of the remaining time on a screen and timer values must be easily set.
Does such APP exist for standard switching lights on or off and that can easily adapted for this purpose ?
The goal is to use this to learn unskilled youth to work in takt time, i got an offer to do this with Siemens touch panels and S5 or S7 hardware but this is much too expensive for us.
BMS Doug
Re: Switching Lights On and Off with a timer
Wed Oct 01, 2014 1:56 pm
pcanu wrote:Hello everyone this is my first post on this forum.
I'm not aware of anything currently existing but this is a fairly simple application to achieve.
You would need a display module with RTC (real time clock), you could either get a 16x2 LCD or a TFT touchscreen.
then you just need to add your light output, this should probably be driven by a relay or solid state relay if it is going to be a bright light.
Programming it would not be particularly difficult.
Doug.
pcanu
Thu Oct 02, 2014 6:43 pm
Thanks for the info Doug.
ranpitime
Fri Oct 10, 2014 4:10 am
would recommend to use CODESYS plc and webvisualisation (show the elapsed time on android or iphone) for this
https://www.youtube.com/watch?v=_MeQBfQObgk
cheers
tonychang-uk
Sun Oct 12, 2014 6:50 pm
use our Smarthome system can do this control
http://www.pridopia.co.uk/pi-smarthome.html
