thomas_pittin
Control 2 dc motor with joystick and L293D
Sun Sep 21, 2014 11:01 am
Hello all,
I explain my request
I use a raspberry pi rev. B, 2 DC motor and 1 L293D
I connect the DC motor to L293D, raspberry pi
I also plug the usb joystick to my raspberry pi
my problem is: how can I control my DC motors with the joystick?
thanks in advance
BMS Doug
Re: Control 2 dc motor with joystick and L293D
Sun Sep 21, 2014 7:32 pm
First you need to prove the L293 is connected correctly by writing a simple program to run the motors backwards and forwards.
Once you have the motors setup correctly you will need to handle translating the USB joystick commands into your (already working) motor driving program.
Your USB Joystick will need to already have linux drivers (preferably already have Raspberry Pi drivers). Hopefully your joystick will have the required documentation for you to proceed further.
Doug.
Building Management Systems Engineer.
thomas_pittin
Sun Sep 21, 2014 7:57 pm
The connection of the L293D is correct because I try a simple program that show me the moviments of the wheels.
how can I translate the USB joystick commands into my motors driving program?
I don't know how can I do
thanks
Ferdinand
Mon Sep 22, 2014 12:33 pm
Hello Thomas,
I found this post:
http://www.raspberrypi.org/forums/viewt ... 9&p=354237
Good luck with your project.
Success with your project!
Ferdinand
