ptx
Piface + sensors = piface in a breadboard
Thu Jul 10, 2014 1:38 am
Hi guys,
I need to configurate my piface and sensors but piface don't support 1-wire ...so
I need to setup my piface (on a breadboard) to get some pin of the gpio free
any help?
thanks a lot!
:D
Toshibass
Re: Piface + sensors = piface in a breadboard
Thu Jul 10, 2014 6:49 am
One way is to use a humble pi breakout board, discard the supplied 26pin female header and instead solder a 26pin female extender header, plug in the humble pi to the PI first then the piface on top, on the humble pi board you can bring out any pin from the PI gpio port and add you sensor connections etc
ptx
Thu Jul 10, 2014 1:28 pm
hum... yeah, i was thinking in something like idle cable, master/ slave configuration... I know piface dont use all the pins, but i dont know the piface schematics for the board... any help?
thanks a lot
jsobota
Thu Jul 10, 2014 2:29 pm
PiFace Digital is connected to RPi via SPI so it uses only a few pins (MOSI, MISO, SCLK, GND, 3.3V, 5V). Using e.g. GPIO#4 for 1-Wire is possible, you just need to solder the wires to the unused pins on PiFace.
ptx
Thu Jul 10, 2014 10:33 pm
thanks guys,
I going to look for some piface datasheet I guess
