kazz
Reading or Detecting newly attached Dallas 1-wire sensors
Wed May 28, 2014 5:00 pm
If you are newly attaching Dallas 1-wire sensors such as DS18B20 temp sensors, to your Rasp Pi GPIO pins, the following script may help, as you add each sensor on to the bus. It will quickly let you see
o it is visible or not
o temp reading from the DS18B20
o device unique ID
Hope it is helpful
Save it as devices.sh and execute it with ./devices.sh on the command line
#!/bin/bash
echo
echo DS18B20 Sensors detected on the 1-wire Dallas bus, and readings at $(date +"%H:%M:%S") on  $(date +"%a %d %b") are ..
echo
counter=0
SENSORS=$(cat /sys/bus/w1/devices/w1_bus_master1/w1_master_slaves)
for item in ${SENSORS[*]}; do
let counter=counter+1
TEMP=$(cat /sys/bus/w1/devices/$item/w1_slave | grep t= | cut -f2 -d= | awk '{printf "%2.2f\n",$1/1000}' )
echo sensor$counter = $TEMP degC, deviceID = $item
done
echo
DeeJay
Re: Reading or Detecting newly attached Dallas 1-wire sensor
Thu May 29, 2014 1:13 pm
I've seen a number of queries about 1-wire sensors on these forums, so I'm sure this diagnostic will be helpful.
But may I point out that it does not behave very elegantly if there are no such sensors detected:
[email protected] ~ $ sh kazz.sh
DS18B20 Sensors detected on the 1-wire Dallas bus, and readings at 13:09:00 on Thu 29 May are ..
cat: /sys/bus/w1/devices/w1_bus_master1/w1_master_slaves: No such file or directory
kazz.sh: 13: kazz.sh: Bad substitution
