thunder
Voicecommand from PiAUISuite no such file or directory
Sun May 25, 2014 7:11 am
Hello. I have problem with voicecommand. I was installed from Install/InstallAUISuite.sh. After that when I type in terminal voicecommand -e or -s or voicecommand without parametrs bash answer /usr/bin/voicecommand: No such file or directory but man voicecommand work. I no have idea what doing. Please help me
DeeJay
Re: Voicecommand from PiAUISuite no such file or directory
Sun May 25, 2014 8:32 am
The Crystal Ball is a little cloudy this morning, so it took a while to find a reference to the package you are installing...
Presumably this - http://stevenhickson.blogspot.co.uk/201 ... e-and.html
[email protected] ~ $ git clone git://github.com/StevenHickson/PiAUISuite.git
Cloning into 'PiAUISuite'...
remote: Reusing existing pack: 680, done.
remote: Counting objects: 5, done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 685 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (685/685), 3.78 MiB | 694 KiB/s, done.
Resolving deltas: 100% (375/375), done.
[email protected] ~ $ cd PiAUISuite/Install/
[email protected] ~/PiAUISuite/Install $ ./InstallAUISuite.sh
Installing AUI Suite by Steven Hickson
If you have issues, visit stevenhickson.blogspot.com or email [email protected]
Maybe there is a clue in that last line...
Does your installation succeed as shown in the author's video?
When I tried, voicecommand was installed into /usr/bin -
[email protected] ~ $ which voicecommand
[email protected] ~ $ file /usr/bin/voicecommand
/usr/bin/voicecommand: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x6215c9f624fe1e3e37b8abb173b7e4c35046aceb, not stripped
The above examples are using the Jan 2014 release of the Raspbian OS - you don't mention what Operating System is running on your RPi.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
thunder
Sun May 25, 2014 8:38 am
Yes correctly as in video.
[email protected] ~/PiAUISuite/Install $ file /usr/bin/voicecommand
this command reply the same what you show me.
Sorry my system is Raspbian
DeeJay
Sun May 25, 2014 9:00 am
If you have that executable in /usr/bin I have no idea why it would not run when you enter it at the command line. (Unless you have modified your path environment variable.) I suggest you ask the author.
thunder
Sun May 25, 2014 9:50 am
I was asked him on twitter but unless he don't like answer :(
I using libboost in version 1.49 is this good version for voicecommand? in apt-get I have only this version
thunder
Mon Oct 13, 2014 8:01 pm
Finally I was resolved this problem. From image card with voicecommand everything is working. :) Thanks for help
