DougieLawson wrote: ↑Wed Jul 25, 2018 9:18 pm
With a
DS3231 you're much better off using the built-in linux kernel driver which is activated by adding a simple line to /boot/config.txt
Doing your own thing with a python program is a waste of time (excuse the pun).
Hardware clock, software clock, and fake clock reading notes
Well, for linux newbies, everything is hard. It took me hours to partially understand the term dt (Device Tree). And I still don't understand thoroughly why "overlay" (over write?)
And for newbies, fiddling with low level drivers installation using sudo nano is dangerous. Actually, everything involved sudo is dangerous, I mean, for newbies.
Anyway, to appreciate the difficulty of installing the built in RTC
DS3231 linux kernal driver, I am reading the Arch linux article on how to use the driver commands, and made a summary.
By the way, even the term 'kernal' scares away Rpi newbies, who have already been hopelessly spoiled by the very sweet Windows plug and play (auto detect, auto install hardware drivers, no questions asked, or at most some click click click, and job is done!).
Hardware clock, software clock, fake clock - ArchLinux last edited 2018aug03
https://wiki.archlinux.org/index.php/Time
Standard behavior of most operating systems is:
- 1. Set the system clock from the hardware clock on boot.
- 2. Keep accurate time of the system clock, see #Time synchronization.
- 3. Set the hardware clock from the system clock on shutdown.
Hardware clock commands
Read hardware clock
# hwclock --show
Set hardware clock from system clock
# hwclock --systohc
Software clock commands (System clock)
The initial value of the system clock is calculated from the hardware clock, dependent on the contents of /etc/adjtime. After boot-up has completed, the system clock runs independently of the hardware clock. The Linux kernel keeps track of the system clock by counting timer interrupts.
Read software clock (and hardware clock?)
$ timedatectl
Set system clock directly (manual, by hand!):
# timedatectl set-time "yyyy-MM-dd hh:mm:ss"
Hardware clock time standard (UTC etc)
To query and hardware clock time standard, eg UTC (Arch command)
$ timedatectl | grep local
RTC in local TZ: no
To change the hardware clock time standard to localtime, use:
# timedatectl set-local-rtc 1
To revert to the hardware clock being in UTC, type:
# timedatectl set-local-rtc 0
UTC commands in Ubuntu
Time skew
Every clock has a value that differs from real time (the best representation of which being International Atomic Time); no clock is perfect. A quartz-based electronic clock keeps imperfect time, but maintains
a consistent inaccuracy. This base 'inaccuracy' is known as
'time skew' or 'time drift'.
The
Network Time Protocol (NTP) is a protocol for synchronizing the clocks of computer systems over packet-switched, variable-latency data networks.
The following are implementations of such protocol:
Network Time Protocol daemon — The reference implementation of the protocol, especially recommended to be used on time servers.
http://www.ntp.org/ || ntp
sntp — An SNTP client that comes with NTPd. It supersedes ntpdate and is recommended in non-server environments.
systemd-timesyncd — A simple SNTP daemon that only implements a client side, focusing only on querying time from one remote server.
https://www.freedesktop.org/wiki/Software/systemd/ || systemd
OpenNTPD — Part of the OpenBSD project and implements both a client and a server.
http://www.openntpd.org/ || openntpd
Chrony — A client and server that is roaming friendly and designed specifically for systems that are not online all the time.
https://chrony.tuxfamily.org/ || chrony
ntpclient — A simple command-line NTP client.
http://doolittle.icarus.com/ntpclient/ || ntpclientAUR
Fake Hardware Clock
alarm-fake-hwclock designed especially for system without battery backed up RTC, it includes a systemd service which on shutdown saves the current time and on startup restores the saved time, thus avoiding strange time travel errors.
Install fake-hwclock-gitAUR, start and enable the service
fake-hwclock.service.
.END
