Batteriesnotincluded
Wireless communication other than putty
Mon May 05, 2014 11:12 am
I am wanting to control my RPi remotely by laptop PC, but putty doesn't work because it comes up that connection has been denied by my network.
Any other programmes I could use to remotely control the RPi that aren't putty?
Re: Wireless communication other than putty
Mon May 05, 2014 11:15 am
Mon May 05, 2014 5:06 pm
Ps
Must have ssh capabilities
RobHenry
Mon May 05, 2014 5:48 pm
Putty is not the problem. The problem is with your network configuration, the set up of your R-pi, or something that you are doing wrong. Either provide detailed information about your set up, what you are doing and what errors you see, or search for ssh problems.
Mr. Pi
Tue May 06, 2014 5:51 pm
It's not like bam. Go onto Raspian, grab your raspberry pi's ip, then in the terminal, type: raspiconfig
then enable ssh
AND THEN.... Select the SSH option on putty. put ur raspberry pi's ip in and it should work!
However, I never did this myself, but am planning to!
\\ Mr. Pi //
____________________
\\ Your friendly Geek! //
