BMS Doug wrote:Tarcas wrote:
In that case, just write a shell script to send a brief inaudible tone at low volume to the speakers, wait 5 minutes, and do it again. Not sure how it'll affect any music that's currently playing, or how exactly to define "inaudible tone" and "low volume." These will probably require some experimenting.
Alternatively, any time you're going to start music or whatever, just have it play something the exact length of the wakeup cycle before starting the actual sound you want to hear. Then you still get the reduced power usage. You still have a delay, but at least your own media isn't cut off at the start.
I don't think the pi is intended to be the primary sound source, just desired to be a snooze button on the eco function (using the second input).
Some experimentation is needed:
What is the effect of two sources being active at the same time?
How long does the source need to be active to prevent shutdown?
Is there a minimum volume or frequency required to prevent shutdown?
First of all, thank you for your kind reply. I did not expect to get so many messages regarding this small issue, but I'm overwhelmed by all the great suggestions on here! You are correct, I was looking for a way to keep the speakers active and prevent them from slipping back into "standby" mode. In answer to your questions:
1. Having two sources active keeps the speakers on. Playing sounds in both sound inputs on the speakers will mesh the noises together if played simultaneously (i.e., if my iPod and PC are connected to them, email alert chimes can be heard over the music).
2. When in standby mode, it seems to take the speakers good 2-3 seconds from the time I push play on the iPod to finally hear the music.
3. I am unclear on this at the moment, but I will test this out first thing next week. I know that simply moving from song to song on the iPod generates these light "click" noises, and those are enough to wake the speakers up (after 2-3 seconds of constant clicking of course).
I liked the previous commenter's idea of generating an inaudible pulse every 5 minutes to keep them awake, however this would of course take concern #3 of yours into consideration. I will test this out on Monday and let you know how it goes (I see there is a YouTube video of 10 minutes of silence, so this should be a perfect test
