juanmol
i've the hardware, i need help with the code (miniCNC 3axis)
Mon Mar 31, 2014 2:21 pm
Hi, i'm sure you had seen http://automate-everything.blogspot.com ... i-cnc.html. I'm trying to do a 3-axis cnc with the same hardware. I've build all the structure (3 steppers, no laser), have the 3xL9110s dual bridges, the raspberrypi, the power supply ... now i need the software!. Reading:
1- make a design in InkScape - OK
2- Export it to GCodes - A half
3- Use a software to engrave it - FAIL!!
May anyone help me, please?
MrGreg
Re: i've the hardware, i need help with the code (miniCNC 3a
Mon Mar 31, 2014 9:45 pm
@ 2.
See
http://www.cnc-club.ru/forum/viewtopic.php?t=35
This works well, although Inkscape EXtreeeeeeemly slow on a Pi. So you might want to generate your gcode on something a bit quicker
@3.
Contacting the original author(s) would seem the best bet first. I note there is no comments/questions on link page.
There are proven and working cnc solutions for RPi
Eg
This, obviously
http://www.raspberrypi.org/phpBB3/viewt ... 37&t=33809
Perhaps less obviously. and not as good, but simple and works
http://www.raspberrypi.org/phpBB3/viewt ... 74#p272674
