After writing a tutorial/blog post about it (which is below), I came to taking a video to show it working, when I discovered after a random period of time, it stops working. Sometimes the python program exits, sometimes it continues printing the direction the car should be going (meaning the python program is still running). Sometimes the car stops, sometimes it continues doing whatever it was doing when the program quitted (eg if the program quitted round a bend, it would continues turning, if it quitted on a straight, it would continue straight). I was hoping to show this at the Cambridge Raspberry Jam on 8th Feb but this issue needs to be overcome.
Here is a video of it not working (it stops working at 1:05, this time it continued printing the direction to the command line): http://www.youtube.com/watch?v=22DHk18ivx0
I have noticed it tends to stop working when it is printing right to the command line, just an observation. Could this be the cause?
PLEASE HELP ME FIX THIS PROBLEM!
Below is the blog post that I wrote on how to build it (this should give you all the information you need to help me fix it, if you need any more, just ask!):
Parts:
Raspberry Pi
Polulu robot chassis
2x Micro metal gear-motors
4x AA batteries
5v USB battery pack mobile phone charger
330ohm resistor
470ohm resistor
HR-SC04 sonar module
2x Digital line detectors
Ryanteck's MCB
Varied jumper wires
SD card
Keyboard
USB wifi dongle
Micro USB cable
Estimated bill of materials: £60 incl. Raspberry Pi excl. Screen, internet connection, local wireless network and laptop to program pi and watch video stream
Wiring and circuit:
http://t.co/pEyHpc0E0x
Code:
#run these commands before this file to start stream:
#mkdir /tmp/stream 2>/dev/null
#nohup raspistill --nopreview -w 640 -h 480 -q 5 -o /tmp/stream/pic.jpg -tl 500 -th 0:0:0 -t 9999999 &
#LD_LIBRARY_PATH=/usr/local/lib mjpg_streamer -i "input_file.so -f /tmp/stream -n pic.jpg" -o "output_http.so -w /usr/local/www" &
#import necessary modules
import RPi.GPIO as GPIO, sys, threading, time
#use physical pin numbering
GPIO.setmode(GPIO.BOARD)
#set up digital line detectors as inputs
GPIO.setup(3, GPIO.IN)
GPIO.setup(22, GPIO.IN)
#set up motor control pins for RTK-000-001
#use pwm on inputs so motors don't go too fast
GPIO.setup(11, GPIO.OUT)
p=GPIO.PWM(11, 20)
GPIO.setup(15, GPIO.OUT)
q=GPIO.PWM(15, 20)
GPIO.setup(12, GPIO.OUT)
a=GPIO.PWM(12,20)
GPIO.setup(16, GPIO.OUT)
b=GPIO.PWM(16,20)
#turn off motors
GPIO.output(11, 0)
GPIO.output(15, 0)
GPIO.output(16, 0)
GPIO.output(12, 0)
# Allow module to settle
time.sleep(0.5)
# Define GPIO to use on Pi for sonar
GPIO_TRIGGER = 7
GPIO_ECHO = 8
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT) # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN) # Echo
# Set trigger to False (Low)
GPIO.output(GPIO_TRIGGER, False)
time.sleep(0.5)
#make a global variable to communcate between sonar functiona and main loop
globalstop=0
def sonar():
while True:
global globalstop
global GPIO_TRIGGER
global GPIO_ECHO
# Send 10us pulse to trigger
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
count=time.time()
while GPIO.input(GPIO_ECHO)==0 and time.time()-count<0.1:
start = time.time()
stop=time.time()
while GPIO.input(GPIO_ECHO)==1:
stop = time.time()
# Calculate pulse length
elapsed = stop-start
# Distance pulse travelled in that time is time
# multiplied by the speed of sound (cm/s)
distance = elapsed * 34000
# That was the distance there and back so halve the value
distance = distance / 2
if distance<20:
globalstop=1
print("Too close")
else:
globalstop=0
print("Far")
time.sleep(1)
threading.Timer(1, sonar).start()
try:
while True:
if GPIO.input(3)==1 and GPIO.input(22)==1 or globalstop==1:
b.stop()
GPIO.output(16,0)
a.stop()
GPIO.output(12,0)
p.stop()
q.stop()
GPIO.output(11,0)
GPIO.output(15,0)
print('stop')
elif GPIO.input(3)==0 and GPIO.input(22)==0:
p.start(60)
a.stop()
GPIO.output(12, 0)
q.start(60)
b.stop()
GPIO.output(16, 0)
print('straight')
elif GPIO.input(3)==1:
q.start(100)
p.stop()
GPIO.output(11,0)
b.stop()
GPIO.output(16,0)
a.start(100)
print('right')
elif GPIO.input(22)==1:
q.stop()
GPIO.output(15,0)
p.start(100)
a.stop()
GPIO.output(12,0)
b.start(100)
print('left')
except KeyboardInterrupt:
GPIO.cleanup()
sys.exit()
I used the instructions on recantha’s and Miguel Grinberg’s blogs to do a live stream.
It uses mjpg_streamer to stream stills from the camera. You basically set up your camera to write single pictures to /tmp in timelapse mode and then mjpg_streamer pseudo-streams from the single image file.
Firstly, set up mjpg_streamer: http://blog.miguelgrinberg.com/post/how ... spberry-pi
Commands to start the stream:
The second one uses raspistill’s time-lapse command to take photos 500 milliseconds apart for 9999999 milliseconds and writes them to the same file (/tmp/stream/pic.jpg) which means every photo overwrites the last. So the photo at /tmp/stream/pic.jpg will always be a photo taken less than half a second ago. The ‘&’ symbol means it runs in the background so we can run the next commands and do other things while it’s running.
The third one starts the mjpeg-streamer streaming the /tmp/stream/pic.jpg file.
After you run these commands (you must’ve installed it before you run them: http://blog.miguelgrinberg.com/post/how ... spberry-pi), you can connect with your web browser and watch the stream live. If you want to watch from within the same Raspberry Pi you can enter http://localhost:8080 in the browser's address bar. If you want to watch from another computer in your network use http://<IP-address>:8080.
Photos:
http://t.co/b8scMKsgqV
http://t.co/Q66n8u9kiE
