ineffective
Pi , java, android, ios based home automation framework
Thu Jan 09, 2014 11:59 am
Hello there!
I wanted to share my recent working with my fellow berry's.
I created a project on github:
https://github.com/Ineffective/Pi-jAutomation433
that allows for controlling power plugs via your smartphone. For now all one can do is add plugs and control them but i intend to greatly enhance this.
I want:
- grouping
- users
- usertracking (via some sensoring, maybe nfc for login/out or checking if smartphone is in wireless)
- timers
- enterprise process manageent based logic (thats where camunda will come in)
My setup:
Hardware:
pi + 433mhz + wifi
433mhz elro power plugs
smartphones
Software: (all inverted are names and can easily be googled for more info)
- Java (8 early acces with hardware float calc)
- Spring MVC for REST Services and all my logic (doing all my heavy lifting)
- H2 Database (lightweight again)
- Jetty server (nice and light)
- RCSwitch & wiringPi doing the low level stuff. I rewrote some of the RCSwitch since it only allowed certain forms of Plug Codes (e.g. not allowing 01010 but only 01000 or 00010 so only one 1 allowed. mine allows any combination)
- ionicframework for the frontend together with angularjs
you can check out my current state here:
https://plus.google.com/108501013982176 ... QRLneobKMW
and a quick glance at the smartphone UI is here:
https://plus.google.com/108501013982176 ... Qw9RK2RV8s
Let me know if anyone has interest in this sort of thing? Wants to help or join me on my quest, thats what github is for
