mikkah33
Door sensor / alarm
Thu Jan 02, 2014 11:10 pm
f
joan
Re: Door sensor / alarm
Thu Jan 02, 2014 11:17 pm
Yes, it is all possible and not particularly difficult.
Have a look through the free MagPi magazine to get some ideas.
http://www.themagpi.com/
mikkah33
Thu Jan 02, 2014 11:21 pm
f
Richard-TX
Thu Jan 02, 2014 11:52 pm
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
mikkah33
Fri Jan 03, 2014 12:01 pm
d
mikkah33
Fri Jan 03, 2014 4:20 pm
g
Tarcas
Fri Jan 24, 2014 9:36 pm
So all you want is for what you've got to repeat? Just put it in a loop that continues forever. I'm not very familiar with Python, but you can google "Python loops" as easily as I can to find the syntax.
You'll probably want it inside your Try block. That way if it gets an interrupt, it breaks right out of the loop and exits.
Have fun!
GroverPenman
Sun Jan 26, 2014 7:32 am
If do not want the students listen to the radios instead of pay more attention to their studies and what their teachers are teaching then using the vip jammer is a helpful method.
boyoh
Sun Jan 26, 2014 5:05 pm
3.3v------( 10KR)-------GPIO I/P-------( C I/R Receiver E )------0v-
5v+--( N/C Door Switch )---( 270R ) ( A I/R Transmitter C )-----0v-
Will this opto Isolator do the practical side of your Project'
1. Door closed Gpio I/P will receive a Active 0 ( low )
2. Door open GPIO I/P will receive a Active 1 ( high )
Recommend the door switch be a Magnetic Reed switch
Less prone to contact bounce
The 10KR is a pull Up Resistor
I might be wrong.....Boyoh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
ThomasS
Sun Jan 26, 2014 7:10 pm
This may not be what you are looking for, but as an early electronics project I made a pressure pad attached to the Pi. It wasn't very difficult at all electronics wise, I just had a plastic box lid which pushed down a DVD case when stepped on :D . The DVD just rested on a push button. It used just three pins, ground, 3.3v constant and a GPIO pin. More recently, I updated it to post to a web server and send email alerts, without much difficulty. All the electronics you need are available on Amazon here http://www.amazon.co.uk/Electronic-Star ... B0082LD2B8 (I used a Raspberry Pi Electornic Starter Kit A from SK Pang), and if you need any assistance I can give you some advice. I used the Raspberry Pi Guy's tutorials and the Raspberry Pi Low-Level peripherals page to get me started.
ThomasS
