ranpitime
Ethercat Master on Raspberry Pi
Thu Dec 26, 2013 10:51 am
an easy way to use the Raspberry Pi as Ethercat Master is to use CODESYS
see here:
http://www.youtube.com/watch?v=3Lzmdy1GxvA
or this
http://www.youtube.com/watch?v=GFN9T_cXLEU
How is that possible?
Steps to use it (you Need CODESYS for it):
1. Register here and download CODESYS V3.5SP4
http://www.codesys.com/download/password-inquiry.html
-> install it
2.
then download the Raspberry Pi Image here:
http://store.codesys.com/accessories/co ... ry-pi.html
boot the pi with that, now yoou could scan the raspberry Pi
Very good for training and education purpose... beside ethercat
ModbusTCP / Master & Slave
Ethernet / IP Scanner
Using PIFace
Using PICam (Trigger Images by plc...)
Webvisu which is executable on Android's and IPhone/Ipad
SoftMotion
is possible...
If anyone need a debian package for installing the plc on his existing Image you need to ask [email protected] for
codesyscontrol_V3.5.4.0.deb ...
ranpitime
Re: Ethercat Master on Raspberry Pi
Mon Dec 30, 2013 5:36 am
here the full link:
http://store.codesys.com/codesys-contro ... pi-sl.html
& Profinet Master will come soon
already possible now:
-Ethernet IP Scanner
-Mobus TCP Master
-Mobus TCP Slave
-Mobus RTU Master
-Modbus RTE Slave
-PiFace using by PLC
-I2C devices
-SPI devices
-Using PiCAM by plc
-Webvisualisation with SSL support
