wkm001
Simple Doorbell
Sat Dec 07, 2013 7:21 pm
Through my searching on this site some of the doorbell ideas are quite impressive. But I want to do something much more simple.
Like most homes, my dogs bark when the doorbell rings. The wire for my doorbell runs through the basement. I want to remove the doorbell and power supply for the doorbell from the equation. Can I detect when two pins on the Pi are shorted by the outdoor switch and send an email? I'll send the email to <My10DigitPhoneNumber>@vtext.com so it will be delivered to my mobile phone as an SMS.
From other postings it looks like I could create a Gmail address for this purpose. But if the script can support SMTP Auth I can use Comcast's SMTP server.
Can someone point me in the right direction?
Re: Simple Doorbell
Sat Dec 07, 2013 10:04 pm
As long as your ISP has port 25 open for you. Then you can send email.
The email doesn't need 100% valid headers, it does need a valid RFC2821 envelope (for GMail). The RFC2822 payload is valid even with bogus addresses. I had to use the reverse DNS lookup for my public IP address for the from address (else Google rejected it).
Start by installing & configuring postfix on your Pi. You've already got python smtplib. It does support authentication if you need it.
Here's a sample (not using authentication):
#!/usr/bin/python
import smtplib
toaddr = 'xxxxxx@gmail.com'    # redacted
me = 'doorbell@194-105-xxx-xxx.ifb.co.uk'    # redacted
msg = """From: Doorbell <doorbell@pi.local>
To: Dougie <xxxxxx@gmail.com>   #redacted
Subject: Door bell ringing
DING DONG
try:
  s = smtplib.SMTP('localhost')
  s.sendmail(me, toaddr, msg)
  s.quit()
except SMTPException:
  print "Error: unable to send email"
wkm001
Re: Simple Doorbell
Sat Dec 07, 2013 10:35 pm
Port 25 is not open.
Re: Simple Doorbell
Sat Dec 07, 2013 10:58 pm
wkm001 wrote:Port 25 is not open.
Are ports 587 or 465 (SMTP SSL) open on your ISP's mail relay?
wkm001
Re: Simple Doorbell
Sat Dec 07, 2013 11:09 pm
I found this thread that is pretty much what I want to do. http://www.raspberrypi.org/phpBB3/viewtopic.php?t=31818
But I have no idea which pins they are talking about our where to put the code.
Re: Simple Doorbell
Sat Dec 07, 2013 11:50 pm
You can use any GPIO pins.
I'd use GPIO22 (pin#15) because it's neighbour (pin# 17) is 3V3.
So now we just need to work out how to use Comcast's SMTP server.
Re: Simple Doorbell
Sun Dec 08, 2013 12:40 am
Start by installing WiringPi2
git clone https://github.com/Gadgetoid/WiringPi2-Python.git
cd WiringPi2-Python
sudo python setup.py install
OR
sudo pip install wiringpi2
#!/usr/bin/python
import smtplib
import wiringpi2 as wiringpi
from time import sleep       # allows us a time delay
wiringpi.wiringPiSetupGpio()
wiringpi.pinMode(18, 1)      # sets GPIO 18 to output
wiringpi.digitalWrite(18, 0) # sets port 18 to 0 (0V, off)
wiringpi.pinMode(22, 0)      # sets GPIO 22 to input
try:
    while True:
        if wiringpi.digitalRead(22):     # If button on GPIO22 pressed
           me = 'doorbell@194-105-xxx-xx.ifb.co.uk'
DING DONG
           try:
              s = smtplib.SMTP('smtp.comcast.net', 587)
              s.login(comcast-userid, comcast-password) # send credentials
              s.quit()
           wiringpi.digitalWrite(18, 1) # switch on LED.
        else:
           wiringpi.digitalWrite(18, 0) # switch off LED.
        sleep(10)                      # delay 10s (which may be too long)
finally:  # when you CTRL+C exit, we clean up
    wiringpi.digitalWrite(18, 0) # sets port 18 to 0 (off)
    wiringpi.pinMode(18, 0)      # sets GPIO 18 back to input Mode
    # GPIO 22 is already an input, so no need to change anything
That program has to run with root privileges.
sudo /home/pi/wireMail.py
FLYFISH TECHNOLOGIES
Re: Simple Doorbell
Sun Dec 08, 2013 12:45 am
wkm001 wrote:Can I detect when two pins on the Pi are shorted by the outdoor switch and send an email?
DO NOT focus just on software part of the implementation !
You shouldn't simply connect wires to RasPi's GPIO and then through basement and frontyard connect the other end to a doorbell pushbutton... this approach warmly invites troubles.
I'd add few elements to keep the troubles away. ;)
I like to use opto-coupletrs for this kind of use cases. The circuit should be located close to RasPi. Additionally, power supply of this circuit could be the same as for RasPi.
Since I don't prefer "ASCII-grapics", I've just draw an example circuit, which should work well for selected components:
Elements are not critical... pick something what is next to your hand. Take the resistor which limits current to around 10-15 mA. Most optocouplers would be fine with this current (but check related datasheet anyway, required current might be higher, specially for older opto-coupler models). Some opto-couplers also require pull-up resistor at the output... check also this.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
Re: Simple Doorbell
Sun Dec 08, 2013 1:00 am
Thanks Ivan.
I'm a software specialist. So I tested the code with a breadboard a resistor and an LED. My quick2wire interface board has a push button (with a 10K pull down resistor).
wkm001
Re: Simple Doorbell
Sun Dec 08, 2013 1:17 am
Looks like the code from the link above takes into account logging in.
# send mail
s = smtplib.SMTP('smtp server')
s.login('user name' , 'Password')
s.sendmail(msg['From'], msg['To'], msg.as_string())
s.quit
print "Email sent"
time.sleep(2)
