vectraboyv6
433mhz cheap power plugs
Mon Nov 11, 2013 5:52 pm
hi,
i have a pi with a cheap 433mhz transmitter and im trying to get these 433mhz power plugs to remotely switch.
https://github.com/dmcg/raspberry-strogonanoff
i'm following this but just cant get it to run the last command just comes back with no wiringpi module installed even tho there is
is there another way I've been using webiopi with some success for temperature measuring.
thanks stuart
vectraboyv6
Re: 433mhz cheap power plugs
Mon Nov 11, 2013 8:24 pm
now trying to use rcswitch-pi which is installed but dont know how to use it any idears?
Hugh Jarse
Tue Nov 12, 2013 7:08 am
kenmc
Tue Nov 12, 2013 11:07 am
vectraboyv6 wrote:now trying to use rcswitch-pi which is installed but dont know how to use it any idears?
I'm using RCSwitch successfully on arduino if that helps. Using Energenie power plugs. Have also got a set of Silvercrest ones from Lidl, but have not tried to capture or tx the code yet.
http://goatstownweather.eu.pn
Ant232
Tue Nov 12, 2013 10:57 pm
I did a similar thing but I used GPIOs to switch the remote that came with the plugs. Not as efficient as using the transmitter though as you need more GPIO pins to get in working. All working using Webiopi. I have attached a pic of the board I built for it. It has 8 opto inputs and outputs so I'm using it to control the heating in the house too.
texy
Tue Nov 19, 2013 8:52 am
vectraboyv6 wrote:hi,
thanks stuart
For installing wiringpi for python, I use PIP. Note that those instructions are a bit dated now as wiringpi is now a version two. To install try this :
sudo apt-get install -y python-pip git-core python-dev
sudo pip install wiringpi2
but you'll need to alter the code to use wiringpi2 instead of wiringpi - maybe alter the WiringPin.py program to
import wiringpi2 as wiringpi
You could also try
and it may just work.
Texy
txt3rob
Thu Nov 21, 2013 1:28 pm
try my project pre made with links to devices
http://www.guthub.com/txt3rob/RPI-Control/
The Raspberry Pi Hell Guy - Random Ramblings to assist me and others.
http://raspberrypihell.blogspot.com
My Github - http:/www.github.com/random-robbie/
http://www.smspi.co.uk - send free uk sms via your raspberry pi from here
thienson30
Fri Nov 22, 2013 11:08 pm
logo raspi-speech2txt with rc antenna.jpg (46.81 KiB) Viewed 8508 times
pyrotuc
Contact: Website AOL
Sun Jan 05, 2014 7:25 pm
the problem may be with wiring up your transmitter. the 433mhz modules that are all over ebay pinout as such: :
_____________/ ____________________________________
| ___ O | | _ =------= |
| (_~_) cccc | | { } o /-\ =|____|= |
| | | {_} \-/ ___ |
|___*_*_*___: : :| | O_________________*__*__*__*_______|
1 2 3 / 1 2--3 4
D 5 G / 5 D G
A V R / V A R
T O O / O T O
A L U / L A U
T N / T N
S D S D
transmitter receiver
that should clear things up. on the receiver, the two middle pins are data, and they are joined. use both or use one, shouldnt matter. its too bad they dont have matching or mating pinouts, i guess that would just be too easy
antennas should be quarter wave (E/Hz=M)*(1/4) yields ~0.173
so this gives us about 17.3 cm or about 6.8 inches
antenna material is not super stringent. piece of magnet wire, piece of wirewrap wire, thin is better than thick, to a point.for whatever reason (poor groundplane? cheap chip?) using shorter or longer can yield much better results instead of what should be formulaically perfect.
Kris Tucker
http://pyrotuc.com
http://pirhotech.com
alias webExposedEmail='rpiforum@pyrotuc.com'
sudo echo "1" > /sys/class/awesome
pyrotuc
Sun Jan 05, 2014 7:26 pm
AAAARRRGGGHHHH i spent freaking forever on that ascii art and its RUINED. *pout*
user your imagination
Kris Tucker
http://pyrotuc.com
Sun Jan 05, 2014 8:48 pm
pyrotuc wrote:AAAARRRGGGHHHH i spent freaking forever on that ascii art and its RUINED. *pout*
Try putting it in [code][/code] tags.
|                          |        |         {_}         \-/                  ___                   |
      1  2  3        /                                          1    2--3    4
   D    5       G        /                                         5          D          G
   A    V       R        /                                            V         A           R
   T    O       O                                                             /                                              O          T          O
   A     L       U                                                          /                                                 L          A          U
          T        N                                                       /                                                   T                       N
          S        D        S                       D
less scrambled that way, but this forum isn't the place for ASCIIart.
pyrotuc
Sun Jan 05, 2014 9:43 pm
Screen shot 2014-01-05 at 3.42.13 PM.png (28.12 KiB) Viewed 7690 times
Kris Tucker
http://pyrotuc.com
pyrotuc
Sun Jan 05, 2014 9:48 pm
it would be nice if the font that is used for the text in this compose box was the same as the font that the posted message would use. in fact, why in the world is it different? makes no sense
looks like yall dont have a font bbcode enabled, is that correct? im rarely on forums, not nearly enough to have noticed these gestalts
Kris Tucker
http://pyrotuc.com
txt3rob
Mon Jan 06, 2014 9:11 am
i have a project that might be suitable
http://www.github.com/txt3rob/RPI-Control/
it uses the cheapo status remotes
FallChallenge
Sun Feb 07, 2016 6:43 pm
I'd like to advice also my open source project ;)
Take a look: https://github.com/roccomuso/iot-433mhz
