tech_monkey
Re: Pi+Cybot or is that Pi-bot
Thu May 10, 2012 8:13 pm
Remember that magazine where you built a robot called Cybot, or Cybor as it was called in Spain.
Well I still have a partly built one. a house move and the birth of our daughter at the time meant I didn't have time to finish it. I have all the magazines and bits. So I was wondering when I get my PI should I rebuild it using this.
For those that don't know it looks like this
A link to info on the little chap.
http://www.casatech.eu
tech_monkey
Fri May 11, 2012 4:49 pm
Been looking a bit more into the possibility of this, and it looks feasible. a few people have done it with Arduinos.
Just need to find the best way to interface everything.
hippy
Fri May 11, 2012 5:42 pm
Happy days - My first ever PICAXE project was a DIY Cybot controller. They Cybot was real value for money if you just got the chassis and the motor control board. That's a simple dual H-Bridge which can be controlled by just four digital signals so should be easy enough to get working with an R-P via GPIO.
The only thing to watch for is not turning both forward and reverse drive on at the same time as that enables both sides of the H-Bridge and shorts the motor supply !
The Cybot was a 5V system so take care with what you connect to where, but I think you should be okay with 3.3V signals into the motor drive board.
It's also not a very good driver so could be replaced with an L293D or similar. The real downside of Cybot is it's motors are pretty noisy but it's a good platform to get started with. I still find them cheap at car boot sales and a charity shops.
Pickley
Thu Jul 05, 2012 9:03 am
Would love to hear any updates on this if there are any?
tech_monkey
Thu Jul 05, 2012 11:16 am
Nothing yet. Still mucking about with Debian Squeeze and Raspbmc at the moment. Plus work commitments are getting in the way :( .
Pickley
Fri Jul 06, 2012 3:11 am
I've got a Cybot sitting around, so this seems like a fun use for it as well.
Just unsure how to go about it. Would I need to protect the GPIO from the Motor Board in anyway?
Mattylad
Sun Sep 23, 2012 8:24 pm
At last - this could be a use for my Pi, as otherwise I cannot find a use for it.
I have 2 cybots, one I collected everything for but the jockey wheel broke and another I got that has a good jockey wheel on.
But ISTR that it had an onboard computer already, so what else do you think you would be able to do with it by using a pi?
Boeeerb
Thu Sep 27, 2012 2:46 am
I've got my Cybot running around controlled via PHP, with an LCD screen hanging off the back displaying current CPU temp and clock (No pic yet).
I plan to add the line follower, distance sensors and impliment an awareness of it's surroundings so it can be told where to go, for instance a charging dock (automatically when batteries start running down).
But using PHP it has been controlled by friends with port forwarding on the router, just needs a webcam on it and anyone can have a go
Find me on Twitter - @Boeeerb
Website - http://www.boeeerb.co.uk
morphy_richards
Thu Sep 27, 2012 7:32 am
This is a big wish but it would be amazing if, for a limited time only, you allowed people from the community to have a go too via PHP/web. And shot some videos for posterity. It would be a first here for that kind of thing. A sort of virtual raspberry pi jam ..
:?: :geek:
Mattylad
Thu Sep 27, 2012 5:48 pm
Yes, it would encourage others to do similar projects.
nhsa
Sat Dec 08, 2012 10:23 pm
I've had some success connecting a Pi to a Cybot - results can be seen here - http://pi.nhsa.co.uk/index.php?page=projects-pibot
Nige
