roboenthus
I2C do not work with MPU6050
Tue Jul 30, 2013 1:59 pm
Up to now, I have followed all the instructions on how to set I2C to work, and the situation now is I can see 68 via i2cdetect or 69 when I pull AD0 to VCC, so the linkage is fine. however, when I try to write bytes to registers, It fails. Nothing can be read either. The same code others use on Pi do not work. The blacklist is clear; I have root permission; I am sure the problem is due to pi, but so far I can not find where is it. Do anyone had such problem or know where the problem is?
Peterloo
Re: I2C do not work with MPU6050
Tue Jul 30, 2013 2:03 pm
Post a photo of the connections between the Pi and the MPU6050.
Richard-TX
Wed Aug 07, 2013 3:57 pm
Maybe your I2c bus speed is too high, cable length too long, or is improperly terminated. Try lowering your clock speed to compensate.
Richard
Doing Unix since 1985.
