Pi Biped Robot walking
Posted: Mon Jun 17, 2013 10:00 am
by mikerr
Not another quadcoptor, a proper biped robot!
I had this previously running - walking! - in arduino, but the pi makes more things cheaply possible (like vision, wifi etc)
He's currently still learning to walk under Pi control .
The legs have 6 servos being controlled by servoblaster.
AFAIK servoblaster can only do a maximum of 8 servos, so when arms and head are added I might have to offload servo control to an arduino.
Re: Pi Biped Robot
Posted: Mon Jun 17, 2013 11:30 am
by Ravenous
So many wires, so little time!
Six servos - can you spell out what they do? I can see the ankle sideways tilt, and maybe a knee/ankle above that. I can't see if the hip has something to twist the leg, or to swing it fore/aft.
The batteries on the head is a good idea - probably helps reduce the sway frequency (if that's the right word).
Re: Pi Biped Robot
Posted: Mon Jun 17, 2013 12:10 pm
by mikerr
Ankle is tilt left/right
Knee is forward/backward
Hip is forward/backward
Re: Pi Biped Robot
Posted: Mon Jun 17, 2013 12:27 pm
by simplesi
What's the basic walk sequence?
Simon
Re: Pi Biped Robot
Posted: Fri Jul 26, 2013 11:56 am
by mikerr
He just took his first steps without falling over:
http://www.youtube.com/watch?v=lgWbgvLjzlY
Re: Pi Biped Robot
Posted: Fri Jul 26, 2013 12:21 pm
by Ravenous
Awww, that looks so cute :mrgreen:
That reminds me, almost time for my next AA meeting . (Only kidding.)
Re: Pi Biped Robot
Posted: Fri Jul 26, 2013 12:39 pm
by mikerr
Hehe, he's already broken part of the top from a drunken fall...
Need to use the knee joints more - then he can walk with less lean, or longer strides.
Re: Pi Biped Robot
Posted: Fri Jul 26, 2013 12:47 pm
by Ravenous
Yeah a bit of knee lift will help, but might also require simultaneous balance from the other leg... Not dared trying any of this myself but planning and programming robot gaits looks very complicated to me...
Still, at least even now he walks better than I dance.
Re: Pi Biped Robot
Posted: Fri Aug 02, 2013 2:48 pm
by mikerr
My nephew Jake (age 8) decided the robot needed dressing and also added cardboard arms and head
Here's the results of his handiwork:
https://www.youtube.com/watch?v=5OQgIfOEktk
As you can see pi-bed also now goes left/right by varying the individual leg's stride length
Re: Pi Biped Robot
Posted: Tue Aug 06, 2013 7:52 am
by mikerr
Kicking a ball:
https://www.youtube.com/watch?v=noObFbk ... ata_player
This runs the knee/hip servos at full speed, instead of slow smoothly interpolated sweeps like used in walking/ leaning
E.g.
Servo.hip = 90
Servo.hip= 140
vs
For sweep in range (90, 140):
          Servo.hip = sweep
          time.sleep (0.1)
(Not actual code)
Next step is to give it some autonomous behaviour (HC-SR04 ultrasonic sensor and/or camera :) )
Re: Pi Biped Robot walking
Posted: Sat Sep 28, 2013 11:13 pm
by raygeeknyc
This looks great! :D kudos!
I was thinking about how to best spend 2 more servos. I think that an arm with one DOF - up-and-down and a gripper would yield a good ROI. In theory, you can position the bot side to side already and you could mount a small camera on the arm. The only problem remains one of balancing when you actually pick up anything substantial, can your robot "lean back" and still walk?
Posted: Wed Oct 02, 2013 4:21 pm
by mikerr
Servoblaster is no longer limited to 8 servos - it's just been upgraded to support up to 21 servos now (17 on a Rev1 Pi)
http://www.raspberrypi.org/phpBB3/viewt ... 77#p420177
So using a couple more servos on arms / head /torso isn't a problem - though the weight (distribution) might be.
I've moved the weighty batteries down directly onto the hip now, so there's more torso movement possible without falling over:
and he can now sit down / lie down after a long day ;)
http://www.youtube.com/watch?v=PEIbgrYKP0I
Posted: Tue Jul 29, 2014 12:44 am
by Inventor_Tommy
Hi
I am keen to get started on a similar project. Do you have an instructables or have your code available on github or another opensource location? It would be really great if your code was shared :-) It would make robotics 101 available for the novice and robotics learner (myself :-)).
Regards
Inventor_Tommy
Posted: Tue Jul 29, 2014 7:40 am
by mikerr
Yes all my code is shared on github
http://github.com/mikerr/biped
Posted: Tue Jul 29, 2014 8:12 am
by Inventor_Tommy
Thank you :-)
Posted: Wed Jan 07, 2015 4:30 am
by LinuxCircle
What batteries did you use to power the 6 servos? How many Amps are required in total? Is 3A sufficient for 6 servos?
Wiring scheme would be appriciated
Posted: Sat Apr 04, 2015 2:30 pm
by [avi]
I was searching for something and landed up on this 2 year old thread.
So...you got any noob level instructions?
Posted: Thu May 14, 2015 4:05 am
by LinuxCircle
[avi] wrote:I was searching for something and landed up on this 2 year old thread.
We built a biped robot and posted Noob Level instruction here: http://www.linuxcircle.com/2015/04/06/l ... -pi-robot/
Let us know or comment on the page if you need further assistance
