krishprasads
PHP to control Python scripts (for GPIO)
Sat May 11, 2013 6:13 am
Hi.
I found this piece of code here {http://www.raspberrypi.org/phpBB3/viewt ... =32&t=8429}, that can execute Python scripts from PHP.
I've installed apache2 on the Pi and I'm able to access the PHP script. But when I press the HTML buttons, nothing happens! :(
When I execute the python script via SSH, it works.. so theres nothing wrong with the python scripts I think.
I'm using WebIOPi to monitor the status of the GPIO pins.
Whats the mistake?
PS: I know that this may not be a very safe approach to control the GPIO. I just wanna give it a try though :)
TIA.
geekinthesticks
Re: PHP to control Python scripts (for GPIO)
Sat May 11, 2013 12:16 pm
It's probably a permissions problem. Your script will be running as whatever user apache runs under. I think that accessing GPIO generally requires root access.
austinp
Mon May 13, 2013 5:02 am
geekinthesticks wrote:It's probably a permissions problem. Your script will be running as whatever user apache runs under. I think that accessing GPIO generally requires root access.
Seconded.
