rooster1
current clamp meters
Thu May 09, 2013 9:23 am
Hi
There was some discussion some time ago about reading domestic electricity meters with a Pi and the best solution seemed to be counting the LED flashes using a photoresistor.
In the case of older meters, it seems we need to use a current clamp http://www.powermeterstore.com/p8578/efergy_xl.php which outputs a 50Hz voltage (of 0- few volts) which is in someway related to the 50Hz current.
The clamp has a jack and I was wondering whether this could be plugged into the audio jack of the Pi and read rather than used as a speaker?
Failing that would need an AD converter - any recommendations?
R
DeeJay
Re: current clamp meters
Thu May 09, 2013 9:34 am
rooster1 wrote:I was wondering whether this could be plugged into the audio jack of the Pi and read rather than used as a speaker?
The 3.5mm audio jack on the RPi is an output not an input.
mahjongg
Thu May 09, 2013 1:57 pm
there is some progress in using the PI's (revision 2) I2S audio interface, so perhaps in the near future it will be possible to have audio-in on the PI.
