aftabs81
Mango M2M on Raspberry Pi
Fri May 03, 2013 11:11 am
I am trying to run Mango M2M on Raspberry Pi. I have tried Mango ver. 1.12.4 as well as 1.12.5.
The java has been jdk-7u21-linux-arm-sfp.tar.gz as well as ejre-7u21-fcs-b11-linux-arm-vfp-client_headless-04_apr_2013.tar.gz
The tomcat6 runs fine and I can see the welcome screen.
The Mango also run but after login and after every click it prompts "a server error has occured ...". When I browse Mango at
local host, it prompts "javasript error .. "
I am a hardware guy and want to know if it makes a difference if a webapp (Mango M2M in this case) is developed on/for x86 platform?
For me, logically, it does not make difference.
Then what problem may have occur, please help?
def10
Re: Mango M2M on Raspberry Pi
Fri May 17, 2013 9:09 am
I'm also looking to run Mango on Raspi. And I have exactly the same problem as you. After some research, it seems that the solution is to look around tomcat. Especially the environment variables ...
Give me some news if you have progressed
inejose
Sat May 18, 2013 11:22 pm
did you find a solution? I'm thinking about to order a raspberry pi just for installing Mango M2M inside...
thanks!
