Bigcat123
Servo HELP!
Sat Apr 13, 2013 5:12 pm
Hello all,
I have just bought 2 servos (listing here: http://www.ebay.co.uk/itm/MG90S-Metal-G ... 2c6d47153e)...
And I want to get both of them working with the Pi! Originally I thought that this was not possible as the Pi only has one PWM pin, but apparently not! I think that I heard that you can control multiple servos with certain software... Servoblaster?
Whilst I am aware of the software, I have absolutely no idea how to use it! There is no tutorials online either!
Can someone help me? Show me how to use my 2 servos? Ideally through Python, but I'm not too fussy!
Bigcat123
Just a beginner sharing his experiences on his way to geek nirvana...
joan
Re: Servo HELP!
Sat Apr 13, 2013 5:34 pm
For a C solution.
https://www.youtube.com/watch?v=2vq0Q4dD6KE
Example code.
#include <stdio.h>
#include "pigpio.h"
P1  Name  gpio    used for
11  ---   17      SERVO 1
12  ---   18      SERVO 2
#define SERVO1        17
#define SERVO2        18
/* forward prototypes */
void servoTick  (void);
int main(int argc, char *argv[])
   int version;
   char str[256];
   /* before using the library you must call gpioInitialise */
   version = gpioInitialise();
   if (version >= 0)
      /* initialise pins, only gpio numbers are supported */
      gpioSetMode(SERVO1,        PI_OUTPUT);
      gpioSetMode(SERVO2,        PI_OUTPUT);
      gpioSetTimerFunc(0, 1000, servoTick);
      while (1)
         sleep(1); /* do nothing */
void servoTick(void)
   static int wid1=1500, wid2=1500;
   static int inc1=50,   inc2=75;
   gpioServo(SERVO1, wid1);
   gpioServo(SERVO2, wid2);
   wid1+=inc1; if ((wid1<1000) || (wid1>2000)) {inc1 = -inc1; wid1+=inc1;}
   wid2+=inc2; if ((wid2<1000) || (wid2>2000)) {inc2 = -inc2; wid2+=inc2;}
To build
cc -o servo servo.c -lpigpio -lrt -lpthread
mikerr
Re: Servo HELP!
Sat Apr 13, 2013 5:44 pm
There's a step by step install for servoblaster in the thread here:
http://www.raspberrypi.org/phpBB3/viewt ... 00#p164500
admittedly it not the first post in the thread.
I've just posted some python code at the end of that thread too:
http://www.raspberrypi.org/phpBB3/viewt ... 54#p330654
Move 2 servos side to side in python
from subprocess import call
from time import sleep
while True:
        call (["echo 1=1 > /dev/servoblaster"], shell=True)
        call (["echo 2=1 > /dev/servoblaster"], shell=True)
        sleep (2)
        call (["echo 1=200 > /dev/servoblaster"], shell=True)
        call (["echo 2=200 > /dev/servoblaster"], shell=True)
        sleep (2)
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 6:12 pm
mikerr wrote:There's a step by step install for servoblaster in the thread here:
while True:
        call (["echo 1=0 > /dev/servoblaster"], shell=True)
        call (["echo 2=0 > /dev/servoblaster"], shell=True)
        sleep (2)
Thanks for the help! The code you have above... What Pins do I need to plug into my Pi?
Bigcat123
mikerr
Re: Servo HELP!
Sat Apr 13, 2013 6:43 pm
Basically looking at this diagram, the dark green pins:
http://elinux.org/Rpi_Low-level_peripherals
Servo 0 = GPIO 04
1= GPIO 17
2= GPIO 18
3= GPIO 21
4= GPIO 22
5= GPIO 23
6= GPIO 24
7= GPIO 25
I.e. I connected the white [middle] servo leads to GPIO 17 and GPIO 18 (1 & 2)
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 8:06 pm
Thanks for your help!
Basically I have installed Servoblaster as per that guys instructions, nothing wrong here as far as I can tell... I then copied your program into a Python 2.7.3 window, and wired up my 2 servos. I wired one to pin 17 and the other to 18... I wired the middle of each of the 3 pins to the 17, 18 pins... You know what I mean? I then connected the 2 furtherest servo pins to 6V and Gnd (On my battery pack)...
I click run....... Nothing happens! What am I doing wrong here?
Bigcat123
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 8:21 pm
Sorry, don't quite understand why you posted that Joan?
Bigcat123
mikerr
Re: Servo HELP!
Sat Apr 13, 2013 8:23 pm
You also need to have a common ground between the pi and the battery pack - a wire from GND on the battery pack to GND on the Pi.
joan
Re: Servo HELP!
Sat Apr 13, 2013 8:28 pm
You need to connect the control wire of the servo to the gpio.
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 8:46 pm
mikerr wrote:You also need to have a common ground between the pi and the battery pack - a wire from GND on the battery pack to GND on the Pi.
Ah... OK, I will do that!
joan wrote:You need to connect the control wire of the servo to the gpio.
Already did that!
Bigcat123
joan
Re: Servo HELP!
Sat Apr 13, 2013 8:51 pm
Bigcat123 wrote:...
Already did that!
Bigcat123
Are you sure? You said "...I wired the middle of each of the 3 pins to the 17, 18 pins... You know what I mean? I then connected the 2 furtherest servo pins to 6V and Gnd..."
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 8:56 pm
joan wrote:
Bigcat123 wrote:...
Already did that!
Bigcat123
Hmm... I am not sure which of the servo pins IS the control one (There is 3 so I am guessing the middle one!?)... I have unplugged everything and I am wiring it up again, carefully!
Bigcat123
joan
Re: Servo HELP!
Sat Apr 13, 2013 8:59 pm
The link you posted shows servos with brown, red, orange leads (to my eyes).
I'd connect brown to ground, red to +5V, orange to gpio.
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 9:03 pm
Wired everything up again... Exactly the same result! Not a twitch... Maybe it is a code problem? Or Servoblaster? When I run the program I don't get any errors... But... I don't know!
Bigcat123
Bigcat123
Re: Servo HELP!
Sat Apr 13, 2013 9:26 pm
They are being run by one battery pack, is that a problem? One servo is hot, the other cold...
Bigcat123
Re: Servo HELP!
Sun Apr 14, 2013 7:05 am
Well, I tried what you said... The servo is definitely wired up correctly! When I connected to power there was a twitch...
However... Running the programming nothing happens, not a thing!
So I wired it up to my Arduino... It worked!
What's wrong with the program? I really need it fixed!
rurwin
Re: Servo HELP!
Sun Apr 14, 2013 7:59 am
Forget programs, do it from the command line.
echo 1=100 > /dev/servoblaster
echo 1=150 > /dev/servoblaster
echo 1=250 > /dev/servoblaster
My servos are only sane with numbers between 150 and 250 IIRC. Yours may vary.
Bigcat123
Re: Servo HELP!
Sun Apr 14, 2013 8:34 am
I tried what you said but it comes up with 'permission denied'... Do you know how to fix that?
Ideally I would like to be able to control the servos from Python...
Thanks again
Bigcat123
joan
Re: Servo HELP!
Sun Apr 14, 2013 8:48 am
Put sudo at the start of the command.
If it works from the command line it will also work from Python.
Bigcat123
Re: Servo HELP!
Sun Apr 14, 2013 8:59 am
Already tried that... Nothing happens the same 'permission denied' message... Any other suggestions?! What is going wrong?!
rurwin
Re: Servo HELP!
Sun Apr 14, 2013 9:04 am
Is there a file called "servoblaster in the /dev directory? If not then you don't have servoblaster installed.
If the file is there, try "sudo -i" and then the echo commands without sudo.
(Edited after joan replied.)
joan
Re: Servo HELP!
Sun Apr 14, 2013 9:05 am
Does /dev/servoblaster exist?
Try
ls -l /dev/servoblaster
mikerr
Re: Servo HELP!
Sun Apr 14, 2013 9:11 am
Try the user version:
cd ~/PiBits/ServoBlaster/
make
sudo ./servod
then the same commands to run it:
sudo echo 1=200 > /dev/servoblaster
Bigcat123
Re: Servo HELP!
Sun Apr 14, 2013 8:11 pm
Yes! Success! It works, turns out I hadn't installed ServoBlaster properly!
I can now make the servo move between 0 and 249 in the command line... However when I tried the original program that you mentioned Mikerr, weird things happened! The servo seemingly moved to random places and twitched and stopped...
Ideally I really need this to work in Python, and with Mikerr's program not working, I have no idea how to do so! Could someone help me? Show me how to do it?
Thanks for the help! You have been great!
Bigcat123
Who is online
Users browsing this forum: No registered users and 6 guests
