epheterson
GPS Project
Mon Mar 04, 2013 4:03 pm
Hey Guys,
I'm working on a project where I'll have the RasPi stationary, collecting GPS data and storing it. Could you guys recommend a GPS and where to get started? We'll also need wireless transmission of the GPS data, would wifi or Xbee be good options? Also GPS accuracy is the most important element here, I believe most of the options tested on RasPi are decent but not stellar accuracy, which is partly why I'm here asking for more options. Any input you may have is awesome!
Thanks,
Eric
gordon77
Re: GPS Project
Mon Mar 04, 2013 4:14 pm
I am sure i've seen threads on here using this GPS dongle
http://mobile.maplin.co.uk/module.aspx?moduleno=476503
Cloudcentric
Re: GPS Project
Mon Mar 04, 2013 4:17 pm
I know everything about nothing"
-rst-
Re: GPS Project
Tue Mar 05, 2013 2:23 pm
Any 'proper' GPS with serial output + either serial-to-USB or GPIO UART with a level-shifter ....maybe if accuracy is the key.
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
skingchico
Re: GPS Project
Sat Mar 09, 2013 5:59 pm
Bluetooth GPS devices are also available. You would need to add a USB Bluetooth device to the Pi so you could talk to the Bluetooth GPS. My Bluetooth GPS has a battery but I keep power applied to it through a micro USB connector since it runs all the time. You mentioned wireless so I figured I would mention Bluetooth.
(EDIT) I may have mis-read the origonal post. You may not be looking for a wireless GPS but I will leave this here anyways.
Steve
ibanezmatt13
Re: GPS Project
Mon Mar 11, 2013 9:19 pm
The best GPS unit and the best tutorial for the Raspberry Pi!
http://learn.adafruit.com/adafruit-ulti ... spberry-pi
coyotebush
Re: GPS Project
Mon Mar 11, 2013 10:34 pm
If you're logging data from a stationary receiver, then it sounds like you are setting up a GPS base station. Are you considering using Rtklib for post-processing?
If setting up a base station, you will need a GPS receiver which outputs "raw" measurements. You also want to use an external antenna.
Here is one example of a low-cost GPS which outputs raw measurements:
http://www.dhgate.com/ublox-lea-4t-gps- ... #s1-1-null
As for antennas, you can start with a patch antenna, but you will want to upgrade once you get things working. Trimble "compact dome" antennas run about $75 used on e-bay and are worth the investment.
joan
Re: GPS Project
Mon Mar 11, 2013 10:39 pm
What's the point of a stationary GPS receiver?
Is it to provide an accurate time source or for earthquake monitoring or what?
coyotebush
Re: GPS Project
Mon Mar 11, 2013 10:42 pm
FYI. Here is a link to some other GPS receivers which provide "raw" data.
http://www.onetalent-gnss.com/ideas/usb-hw-receivers
-rst-
Re: GPS Project
Sat Mar 16, 2013 5:51 pm
joan wrote:What's the point of a stationary GPS receiver?
This is the most typical use I have come across: http://en.wikipedia.org/wiki/Real_Time_Kinematic
xor-function
Re: GPS Project
Thu Sep 25, 2014 7:23 am
This may not be relevant to the op anymore as it's been a year but the following may prove useful for others.
It's a bash script that utilizes the /ttyAMA0 serial connection for gps input and uses a WiFi adapter for pushing data to a remote server.
There's no need to worry about paying for a SIM and it's service.
It's available here:
https://github.com/xor-function/rpi-tracker
You should also be able to use this on different SoC's that run Debian other than the Raspberry Pi as long as you specify the
correct GPS device, /dev/ttyUSB0 for example.
