rurwin
Easy & Cheap DIY Arduino add-on for the Raspberry Pi
Thu Feb 14, 2013 1:43 pm
I just came across this: http://www.paperpcb.dernulleffekt.de/do ... perduinopi
It's a stripboard Arduino that mounts onto the Raspberry Pi. He calls it a paper PCB, but that's a little misleading.
It's worth a glance if only for the clever trick he uses for the header socket -- no stripboard cuts at all.
silverfox0786
Re: Easy & Cheap DIY Arduino add-on for the Raspberry Pi
Fri Mar 29, 2013 9:10 pm
I made that a few weeks ago but couldn't get alamode to work and upload sketches
nice guy wolfgang been helping me as much as he can via email
made a few of my own paper pcbs as well which I shared with wolfgang
silverfox0786
Sun Mar 31, 2013 7:45 pm
got the alamode working and it works really well as a Arduino RasPi Sheild
its a nice alternative for anyone wanting only Arduino on the gertboard as its smaller and works just like a Arduino and can be undocked and plugged into a 5v line
in fact I managed to use it undocked and upload sketches using a ATMEGAu8 FTDI
and run it without the pi
now to redesign it so the pin holes correspond to a real arduino for shield use
yaconsult
Wed Jul 17, 2013 5:58 am
I'm confused! I thought the whole idea of the alamode was that it let you plug in arduino shields when the alamode is mounted on the raspberry pi?
rurwin
Wed Jul 17, 2013 6:31 am
If I remember correctly, the Arduino has an annoying feature that the I/O headers are not separated by multiples of 0.1 inches.
So it is impossible to build one on stripboard and use shields.
toxibunny
Wed Jul 31, 2013 10:33 pm
...unless you use arduino offset headers!
note: I may or may not know what I'm talking about...
kghunt
Sun Aug 11, 2013 7:47 am
Offset headers I thought that is what needle nose pliers were for? :D
