Raspberry Pi 1 controlled RC Car.
Posted: Thu Apr 22, 2021 7:06 pm
by Arminas
Hello, I have a Raspberry Pi 1 (c) 2011.12 and I want to control a RC car with It. I will later put a 4G usb dongle and VPN client to access It from anywhere, but I have no knowledge of python and connecting stuff through GPIO pins on raspberry Pi. Can someone help me connect raspberry pi to a rc car which has 2 motors (1 for forward/reverse, 1 for turning, voltage approx. 3-4 volts.)?
I found this thread: https://www.instructables.com/Raspberry ... Fi-RC-Car/,
using L298N Motor Drive Controller, but some of the links seem outdated, will It work with my RPi 1?
Re: Raspberry Pi 1 controlled RC Car.
Posted: Thu Apr 22, 2021 8:12 pm
by B.Goode
It isn't directly about Robots, but maybe start by looking at https://projects.raspberrypi.org/en/pro ... -computing to get a grasp of the basics of connecting things like motors to an RPi board.
There is a similar project about building a robot buggy: https://projects.raspberrypi.org/en/pro ... ld-a-buggy
Edit: to add - The current (March 2021) release of the recommended RasPiOS Operating System will run on your older RPi board. The thing to watch out for is the compatibility of the 26-way header which has some small differences from the 40-way header on later models. See https://pinout.xyz/
