benmason
aquarium temperature sensor with email
Sat Jan 19, 2013 8:07 pm
Hi All,
I am soon buying a tank to house some turtles. I would like to project a system where my pi monitors the air and water temperature via DS18B20 waterproof sensors.
Ideally I would like the pi to email me a warning stating when either of the sensors are outside of set range (25-29 degrees Celsius.)
I have read http://www.cl.cam.ac.uk/freshers/raspbe ... mperature/ and believe this would work but I need your help working with multiple single wire sensors and with making the pi email when required.
All assistance and comments welcomed.
Best wishes
Ben
yop
Re: aquarium temperature sensor with email
Sat Jan 19, 2013 9:35 pm
I discovered thinkerforge product yesterday (I know i do ads but i find it so cool)
They provide cheap modulable things you can plug to your rasp; you should have a look , they got temps sensor and IR temps sensor so you can mesure, the glass temp and maybe 20cm under water or maybe a stone or something?
albatros
Sat Jan 19, 2013 10:03 pm
I started with my Pi and FHEM http://fhem.de/fhem.html some days ago. I wish I would have found it earlier, because then I would have used it for my two tanks with snakes to controll lights and heating. So I think FHEM could be very usefull for you.
Regards
Uwe
benmason
Sun Jan 20, 2013 12:45 am
Thank you both for your replies, some interesting potential especially with regards automating the heating of the tank.
I will be trying to keep this project as streamline as possible at least for the first attempt, as such ideally I need to work out how to take a reading from the sensor and through a process of continuous monitoring set the above limits. I imagine it to be along the lines of let "Air Temp" = (sensor 1 address) if "Air Temp"= >25.000 then run a script. That script should then send an email warning stating "Air Temp=" to a specifies address. I think I would like the script to take a reading every 30 minutes.
It seems a fairly simple set of processes however I am right at the start of my programming experience.
Can anyone point me towards a tutorial for setting up email notification of sensor readings?
anddav87
Wed Mar 13, 2013 9:42 am
Hi
If you haven't already found a solution, try this that I just uploaded:
https://github.com/anddav87/SendTempWarn
Cheers
Andy
bouncymat
Wed Mar 13, 2013 1:05 pm
this code (adapted from adafruit tutorial) will read multiple temp sensors
import os
import glob
import time
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')
numberof=len(device_folder)
device_file=[0]*numberof
temp_c=[0]*numberof
print numberof
for i in range (0,numberof):
    device_file[i] = device_folder[i] + '/w1_slave'
def read_temp_raw(value):
    f = open(device_file[value], 'r')
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    for ii in range (0,numberof):
        lines = read_temp_raw(ii)
        while lines[0].strip()[-3:] != 'YES':
            time.sleep(0.2)
        equals_pos = lines[1].find('t=')
        if equals_pos != -1:
            temp_string = lines[1][equals_pos+2:]
            temp_c[ii] = float(temp_string) / 1000.0
    return temp_c
while True:
    print(read_temp())
    time.sleep(1)
i am very new to programming so please excuse any silly bits of code.
