Patrick222122
running a program at start up
Tue Jan 15, 2013 9:05 pm
It is any way possible for a program to start running automaticly when the pi starts? My robot I am using my pi to control is very small and has no room for any type of screen or keyboard and I think it would be a pain to connect one everytime it starts up.
repton
Re: running a program at start up
Wed Jan 16, 2013 4:47 am
Either a cron job @reboot as suggested above or stick it in /etc/rc.local is the other common way of doing it.
The advantage of the former is it makes it easy for a non root user to do it, the advantage of the latter is it doesn't rely on cron working.
Paul
UK Supplier of 1-Wire components, kits and modules:
http://www.sheepwalkelectronics.co.uk/
necc
Wed Jan 16, 2013 10:40 am
rc.local is the way to go
Hoagie
Wed Jan 16, 2013 12:55 pm
I use this script to run my electricity meter monitoring program. I run this from a cron job every 5 minutes.
#!/bin/bash
if [ `pgrep MeterMonitor` ]
then
        echo Already running - wont start
else
        echo Starting MeterMonitor
        nohup /home/geoff/meter/MeterMonitor >/dev/null &
fi
