Fly100
Weather Compensation
Sun Feb 16, 2020 4:10 pm
Hello all,
Has anyone ventured into Weather Compensation with a Raspberry pi not using the Open Therm Gateway. I have an Oil Boiler so I cant modulate the output, however Im looking into a ways of altering the Boiler Set point with a raspberry pi using a simple T curve. Of course this will need an external Temp Sensor( or option to download the temp from the intenrent) and a pipe sensor internally.
For example:-
Outside Temp of 10C Boiler Temp to 50C
Outside Temp of 5C Boiler Temp to 55C
Outside Temp of 0C Boiler Temp to 60C
Outside Temp of -5C Boiler Temp to 62C
Outside Temp of -10C Boiler Temp to 65C
DHW temp is not an issue as I have Solar so it will exceed the 60C mark daily.
Thanks,
Fly
