Yorkshire Geek
HX711 odd readings
Tue Jan 21, 2020 8:11 pm
Ok, this is puzzling me. I've been playing with load cells for the first time, I have 4 cells connected through an HX711 as is apparently the customary practice. If I apply a load the reading from the HX711 changes so all appears well but I have two oddities I don't quite understand.
1. The readings are negative rather than positive, Google didn't give me a clear answer on whether that's expected or not.
2. The output with just the load of the empty weighing platform is either around -130k or around twice that with a small number of random data points outside that range. I captured a reading every second for an hour or so and this is what the trace looks like. There's two clear lines, one at X and one at x*2. What could cause that? If it were random noise I'd blame my soldering but this is clearly not random.
Any assistance gratefully received.
joan
Re: HX711 odd readings
Tue Jan 21, 2020 9:31 pm
It's negative because you have two wires swapped. I wouldn't worry about that, it's simplest to just account for that in the software you are using.
Yorkshire Geek
Tue Jan 21, 2020 9:39 pm
Yeah, that one I can account for easily enough, ta for the explanation though. It's the second one I'm really mystified by. I can account for that in software too if I have to but would like to understand rather than just bodging it to discard the x*2 readings.
joan
Tue Jan 21, 2020 10:13 pm
What software are you using?
Yorkshire Geek
Tue Jan 21, 2020 10:26 pm
This library and Python 3. Doing nothing fancy, literally taking the raw value and saving ir.
https://pypi.org/project/hx711/
joan
Tue Jan 21, 2020 10:39 pm
