theend
GPIO read...
Thu Dec 20, 2012 1:50 am
I installed WiringPi. When i typing
"gpio mode 0 in"
"gpio read 0"
then i allways get other values.
1 or 0
The button is connected to: GND(6) and GPIO-17=pin 11
But the button isnt pressed.
Whats the problem?
JPB-HK
Re: GPIO read...
Thu Dec 20, 2012 5:34 am
Did you use a pullup resistor or did you set the internal pullup resistor?
mode 0, up
Not sure the order of this, whether it should go after the mode in command.
John
NCR 310 - ZX81 - Apple II+ - Dell/Intel - Mac mini... Raspberry Pi!
