raspi_rv
Device to measure angle for input to RPI
Tue Jan 14, 2020 7:22 pm
I am new and tried a few searches but no luck.
I am designing a project that will need to measure the angle of an arm relative to horizontal (can be actual as in level bubble or just relative to the mount)
Think of a window in the ceiling where I want to measure how much it is open. I need it to either be wireless or can be wired into some sort of wireless hub for up to a dozen of these devices. Wireless in this case is probably Bluetooth. Power must be from long life battery.
Do such devices exist?
First computer 1959. Analog Ferranti Packard
hippy
Re: Device to measure angle for input to RPI
Wed Jan 15, 2020 6:20 pm
I would have thought a rotary potentiometer, perhaps with some gearing, might be ideal. Possibly a linear potentiometer attached to some linkage.
A microcontroller with ADC input and some sort of on-chip RF connectivity is probably ideal if you are looking for long battery life. There are many very low-cost options there.
Earlton2
Wed Jan 15, 2020 11:05 pm
Inclinometers et al:
https://www.digikey.ca/products/en/sens ... ageSize=25
C$35 ++ over here.
Also used in game controllers so maybe some much cheaper parts are available.
You'll have to go hunt for a low power processor but if it doesn't have Analog in then a NAU7802 is an I2C-ADC.
If it were only to wake up every 30 minutes for the blink of an eye you might get a reasonably long run time from your battery.
