hanna8754
Stepper motor RPM using A4988 and pi 4
Fri Jan 03, 2020 10:55 pm
Hi all,
I am currently using an A4988 Stepper Motor driver with a nema 17 and a pi 4. I have some experience moving motors, but I need help making the motor move at a continuous RPM. I want to run at 1/16th micro steps and between 5 and 50 RPM. I was hoping someone had an example of some basic code or could help in any way.
Thank you so much for any help!
pootle
Re: Stepper motor RPM using A4988 and pi 4
Sat Jan 04, 2020 8:18 am
Why not try the code posted in response to your earlier question?
hanna8754
Sat Jan 04, 2020 3:40 pm
Thanks for the reply, I am. I was unsure if it would work now that I have changed the driver, but I will definitely try it
Thanks for all help!
