MoustacheKitten
Light Automation
Thu Jul 25, 2019 4:57 pm
Hi all.
I am new to raspberry pi. Myself and my parents are going away in december. We would like to put up a system that would automatebthe lights to go on at a certain time at night and then go off in the morning. Also then leave the automation and be able to switch the lights on/off manually. I have read a few forums and watched a few videos. I sort of understand the connections for the pi and relays. What pi would be used in such example?
mahjongg
Re: Light Automation
Thu Jul 25, 2019 5:02 pm
No PI!
Just buy a regular mains timer, either electronic, or electromagnetically.
why would you want to re-invent the wheel, unless as an exercise.
if you insist in using an RPI, any PI will do (or an Arduino).
driving the relay is probably the most problematic part, the common pitfall sticky has some tips:
https://www.raspberrypi.org/forums/view ... 91&t=83372
drgeoff
Thu Jul 25, 2019 5:32 pm
"Sort of understand" is not sufficient. Using relays to switch mains requires that you fully understand theory and practice. Loss of property, limb and even life is easily possible if you do not.
Quis custodiet ipsos custodes?
PhatFil
Thu Jul 25, 2019 7:23 pm
all sorts of home automation options are available to you if the 'away timer' is just an excuse to play with your pi.
you can wire everything up to your pi, but the advice above regarding mains power should be taken seriously
the route i took involves using off the shelf smart sockets and reprogramming them to replace the manufacturers firmware which generally requires a phone app that need permission to do everything just to talk to the socket..
while i do have to open most devices and solder connecting pins or wires to the pcb i do this without them plugged into the mains power.. (some can be rewritten OTA)
My Pi is used to host the communications system (Mqtt Broker) and the software i use to set up automatic responses and provide a gui interface Node Red
rather than code my own firmware to replace the stock systems i use tasmota a very full featured firmware aimed squarely at smart devices.. https://github.com/arendst/Sonoff-Tasmota/wiki
this gives me the ability to include input from any device my pi can talk to via wifi, bluetooth or physically connected via usb or gpio to determine what gets turned on and off automatically.
Other home automation systems you can use on your pi include domotitcz, and Home Assistant each with their own large friendly support communities
evansusu
Fri Jul 26, 2019 7:00 am
https://www.thegeekpub.com/16187/contro ... pberry-pi/
Hi Guys, I followed this tutorial to light up a WS2812b led strip with 60 LEDS using a raspberry pi. Unfortunately it doesn't work.
'import board
import neopixel
pixels = neopixel.NeoPixel(board.D18, 60)
pixels[0] = (255, 0, 0)
After running it, I got this error in the images Image
PhatFil
Fri Jul 26, 2019 1:00 pm
Did you try running with sudo as suggested? that is prefixing the command to run your script with sudo *Super User DO"?
its easier to read if you cut and paste text into either a quote or code block in your posts, photo's of screens are tricky to read.. and code as message text doesn't stand out.
drgeoff
Fri Jul 26, 2019 3:04 pm
@evansusu
Please do not hijack threads which have no relevance to your problem. There is no extra fee to start your own topic.
