2ko
RPi Measurement ability ?
Mon Dec 03, 2012 3:00 pm
Hi all ,
Does anyone knows if RPi has some built in Measurement capabilities like ability to measure temperature,it's input voltage,it's input current or something like that .
I know the question sounds a bit strange but this is what we are looking after right now in our college project -->built in measurement capabilities.
I want to add that I am not interested (at least for now) in EXTERNAL Devices or sensors that can be added to the RPi ,my question is about the bare naked RPi itself with no extra hardware.
Thanks.
2ko.
Dweeber
Re: RPi Measurement ability ?
Mon Dec 03, 2012 3:14 pm
You can get the Temp of the CPU... but that is about it.
$ /opt/vc/bin/vcgencmd measure_temp
temp=43.3'C
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
2ko
Mon Dec 03, 2012 3:34 pm
Dweeber wrote:You can get the Temp of the CPU... but that is about it.
temp=43.3'C
OK thanks a lot Dweeber .
After your hint I also found the
vcgencmd measure_volts
which returned me 1.2 V .
Ravenous
Mon Dec 03, 2012 4:06 pm
Oh that's an interesting thought (well interesting to me anyway) - the 1.2V measurement might come from the core voltage, which I gather the raspi's chip generates internally.
Anyway I believe changing the clock speed is also regulated internally, by a clock multiplier, and wonder if it also has a measurement method you'd be interested in. In other words, is the clock speed actively controlled by a circuit somewhere, or is it just set by some fixed clock divider? (No idea, just suggesting it might be worth looking for.)
