Patrick222122
Re: Raspberry pi and Parallax Propellor
Sun Dec 09, 2012 6:21 pm
thanks for the link. I don't think it will be too much of a problem though. After all I am only using the propellor to be an interface between the motors and bump sensors and the PI. I will simply set Pi and the propellor as the slave
mahjongg
Sun Dec 09, 2012 6:58 pm
errr.. :shock: I think you mean I will set the PI as master and the Propeller as slave. (or vice versa). :roll:
mahjongg
Wed Dec 12, 2012 11:13 am
robotworkshop
Thu Dec 13, 2012 9:54 pm
For an example on how to use serial communications on the Raspberry Pi you can review this thread:
http://www.raspberry-projects.com/pi/pr ... t#more-482
/dev/ttyAMA0
will refer to the built-in console serial port available on the GPIO pins. If you have a Propeller board plugged into the Raspberry Pi (either directly or through a HUB) then it should show up as a tty port probably like
/dev/ttyUSB0
If you replace the /dev/ttyAMA0 with the port of your Propeller board then you should be able to talk to it that way.
Robert
gordon@drogon.net
Thu Dec 13, 2012 11:07 pm
Patrick222122 wrote:I have decided it best to use UART fro the communication between pi and propellor. I would like to know if there is any good posts with samples of UART code or a website with samples. I would like links please.
If you're not already sorted, then :
https://projects.drogon.net/raspberry-p ... l-library/
should help - from C/C++, anyway
-Gordon
Patrick222122
Mon Dec 17, 2012 11:25 pm
Well I am back. It turns out that the book on python I requested to be brought in from Quincy at the library was checked out. Is there any particularly good websites or youtube tutorials on the subject(PS I am a complete beginner with Python)
Patrick222122
Sun Dec 23, 2012 11:50 pm
Okay one more question, From the pictures of the pi on the net the power jack looks like a usb port. Is there any usb power supplies compatible out there and where can I get one?
Patrick222122
Sun Dec 23, 2012 11:53 pm
It will have to be mobile as well.
Patrick222122
Thu Dec 27, 2012 3:24 pm
Okay I have finally got the pi. I need to figure out which pins are for I2C
Patrick222122
Thu Jan 03, 2013 9:57 pm
well I am back. made some progress with the propellor. Decided to use python instead of c and save me some headaches. I still have some problems though and some questions. First there seems to be a bug in my code
import usb
bus=usb.busses()
device=bus[0].devices[0]
_devhandle=device.open()
_devhandle.setConfiguration(1)#this line is the culprit
_devhandle.claimInterface(0)
_bulkout=1
_bulkin=0x82
DeviceID=_devhandle.controlMsg(0xa1,0,8,100)
while x<12:
_devhandle.bulkWrite(_bulkout,32,100)
_devhandle.bulkRead(_bulkin,8,100)
x=x+1
_devhandle.releaseInterface(sekf._intf)
del self._devhandle
I have already checked the configuration of the pi with another program and it said it was one. Second I am planning to start experimenting with a web cam hooked up to the pi very soon, I need to know if I need a driver for my lifecam hd 3000 and where in apptitude I can find it. I also need software to view what the life cam sees so I know it working
