fotoartist78
Using the HC-SR04 ultrasonic receiver
Wed Jul 03, 2019 3:04 pm
Has anyone used the Sensor mentioned in topic header? If so could they make the code they used to pulse & activate it that was used available to me through this forum, I would be very grateful.
joan
Re: Using the HC-SR04 ultrasonic receiver
Wed Jul 03, 2019 3:12 pm
What is wrong with the many solutions offered when you google "raspberry pi sr04"?
fotoartist78
Wed Jul 03, 2019 3:24 pm
Many thanks 'Joan' for your suggestion , I have not tried that so I will do that and hope to find something useful.
joan
Wed Jul 03, 2019 3:32 pm
In your other post you mentioned the Arduino Uno.
Software used on the Pi won't be optimal on an Arduino (strangely enough most of the poor Pi software for the HC-SR04 was ported from a good Arduino solution without considering the differences between the platforms).
pcmanbob
Wed Jul 03, 2019 8:34 pm
Here is some commented code that explains how it works.
it was written for python but could be simply changed to run with python3
#!/usr/bin/python
# Import required Python libraries
import time
import RPi.GPIO as GPIO
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
# Define GPIO to use on Pi
GPIO_TRIGGER = 23
GPIO_ECHO    = 24
# Set pins as output and input
GPIO.setup(GPIO_TRIGGER,GPIO.OUT)  # Trigger
GPIO.setup(GPIO_ECHO,GPIO.IN)      # Echo
# Set trigger to False (Low)
GPIO.output(GPIO_TRIGGER, False)
print "Ultrasonic Measurement"
# Allow module to settle
time.sleep(0.5)
# Send 10us pulse to trigger
GPIO.output(GPIO_TRIGGER, True)
time.sleep(0.00001)
start = time.time()
while GPIO.input(GPIO_ECHO)==0:
  start = time.time()
while GPIO.input(GPIO_ECHO)==1:
  stop = time.time()
# Calculate pulse length
elapsed = stop-start
# Distance pulse travelled in that time is time
# multiplied by the speed of sound (cm/s)
distancet = elapsed * 34300
# That was the distance there and back so halve the value
distance = distancet / 2
print "Distance :", distance
# Reset GPIO settings
GPIO.cleanup()
One other thing you should be aware of is if you are using a 5v HC-SR04 then you need to reduce the echo pin voltage before connecting it to you pi gpio.
like this
